Old 09-21-2010, 07:22 AM   #16
Originally Posted by Pat View Post
Hey guys!
I'm looking for some tips on how I can get my TA04 going faster in the stock class. The restrictions are 90/30 gearing on a Johnson/Mabuchi 540 and no speed tuned gears or flat chissis' (tubs only). I don't have alot to spend on hopping it up so what are some general tuning tips and all that I can do which will really help me get ahead of the pack?
Thanks alot.
I have lots of experience with this car. More than most. You don't need to much to get it going. Here's a basic set-up. You will usually never have to change it.
front shocks (3) hole pistons 50 weight oil tamiya white springs
rear shocks (3) hole pistons 40 weight oil tamiya blue springs
stand the front springs all the way out on the front shock tower and arm
stand the rear shocks second hole out and second hole out on the arm
run a front one-way and if possible run a center one-way
5 droop on the front and 4 droop in the rear
your rear gear diff is fine. I've tested them and have gone the same speed with both.
Run 2 degree's rear toe. (2) degrees of camber all the way around and 5 degrees ride height. I've only run the tamiya nsx body with this car. Put a large screw driver handle on the front belt between runs. Don't worry the belt will get tight like original.(not good) Keep it as loose as possible. Just run your electronics. All that extra stuff really doesn't help that much if they work. Add some roll to your car in the remote. Make sure to adjust your steering throw left and right and your dual rate.
Hope this helps.
Also put the blue swaybar on the front.
Juan Aveytia is offline   Reply With Quote
Old 09-21-2010, 07:26 PM   #17
KoE's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to KoE
Originally Posted by Azr View Post
Still a good car
damn right...still have one
KoE is offline   Reply With Quote
Old 09-21-2010, 08:23 PM   #18
Azr's Avatar
Send a message via Yahoo to Azr
Azr is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 06:37 PM
TA04 Setp Tips for Northside Track?? Coney Australian Racing 1 02-08-2004 01:34 AM
HELP!! TA04 Setup for Summer Nats (Stock) Rod M Australian Racing 5 01-22-2004 05:38 PM
Tamiya TA04 R Spec, TA04 Parts, F201 Parts, TC3 & Misc. izzyracer R/C Items: For Sale/Trade 11 12-08-2003 11:12 AM
TA04-R with Tamiya Stock Type RR motor. what pinion? jbrians Rookie Zone 5 01-28-2003 01:47 AM
SEO by vBSEO 3.5.0
