Old 12-05-2007, 08:28 PM   #1
gurumods's Avatar
Default Help fixing a shorted lipo
A friend crossed polarity on a Orion 3200 7.4 lipo tonite and it does not work now.I brought it home with intentions to try and fix it for him.As i seperated the case each cell stayed in it's own half and i am afraid to try and pull it apart any further in fear of damaging one of the cells.I can see a tab on the + positive side that has been burnt/shorted and i think if i could get these two halves apart a little further i might be able to operate on this battery.First of all,is it just a matter of resoldering that tab back where it goes or what ?.Someone told me last week to contact them if this ever happened,but i forget who it was.
gurumods is offline   Reply With Quote
Old 12-05-2007, 09:05 PM   #2
Contact Orion before you do anything!!!!!
_pilot_ is offline   Reply With Quote
Old 12-05-2007, 11:11 PM   #3
There is thin double sided tape on the cells holding the case halves,just resolder the fuse,all is good.no biggie
kozman is offline   Reply With Quote
Old 12-06-2007, 12:23 AM   #4
FrankW's Avatar
Most lipoly cells have aluminum tabs that are welded together. You can solder it, but you need special solder. Good luck and keep a fire extinguisher handy.
FrankW is offline   Reply With Quote
Fixing AMB transponder Roelof Nitro On-Road 22 07-29-2008 08:43 PM
Thanks for fixing RC Tech!!! rccardr Electric On-Road 29 02-26-2008 11:16 PM
Help, shorted cells. rbecking Electric On-Road 3 01-18-2007 05:13 PM
Ever Shorted An Armature? tmeeks Electric On-Road 4 06-08-2004 09:20 PM
Reciever shorted? Rob Hochberg Electric On-Road 7 01-09-2004 01:52 PM
SEO by vBSEO 3.5.0
