Building a power supply
I am currently using a 4 cell 3000 pack on my lathe, but would like to also have a power supply to use.
Anyone know a place online where I can find a guide to building a power supply?
Any help is GREATLY appreciated.
Thanx.
Thanx.
cant build it but you can buy it, you would have to be a genius to make one
yeah you can get a good power supply now for about $100 so it will save you a headace if you just drop the 100 and be done with it. but im sure if you wanted making one shouldnt be that hard
I've done the PC power supply conversion and it is very easy. Just read the instructions and follow them to a T. You can save yourself a crapload of money by doing this. Works great, charges my batteries at 6A if I need it. Best of all it was salvaged and free.
I've built my own Transformer-rectifier-regulator Power supply.
--heavy
Then I tried converting PC pwer supplies
--wimpy. Voltage drops below 11V on high loads
Now I'm happily using an Eagle 18 amp power supply.
Just go buy a commercial PWM supply. It will save you headaches plus it's easier to sell them when you need money compared to a homebuilt one.
--heavy
Guest
--heavy
--heavy
Bryan
Guest
Originally posted by donoman
.........Best of all it was salvaged and free.
Bryan
He's looking for a power supply to run his lathe. He doesn't mention charging so low voltage or amperage on the 12v side shouldn't be a problem.
I've got a couple of these and both work well.
The first one is an old 250w AT type. With 4 resistors (I'v forgotten the values) across the 5v tap I have enough power to run 2 chargers at 5a. The only problem is starting the second charger it goes into overload. Solved this by getting a big azz (beer can) size capacitor. The other problem is that certain chargers need a certain amount of over voltage to operate properly. My Tekin BC112 seems to need about 2.5v-3v over the batteries peak voltage to operate. If the battery peaks much over 10v it chokes and goes into low power error. My Novaks don't have this problem.
I got the second one to do just what Galactic wants, run my lathe. It's 155w ATX unit. It has 15a at 5v and 14a at 3.3v. Had no use for 12v in this one so I didn't install any resistors on the 5v tap. The 5v runs my lathe great and I use the 3.3v to break in my stock motors. It will also break in 19t motors if they don't need a lot of start up amperage. I don't think it will start up mod motors.
Best part is I got it from www.mpja.com for about 20 bucks. About 5 or 6 bucks for a switch and jacks an old computer cord and your in business.
ok, so let me get this right...
the +12V 15A is going to give me a positive 12volts and 15amps. Which is what I need for my Duratrax ICE charger.
Wiring coming off an industry standard circuit board will be:
ORANGE +3.3 V
YELLOW +12 V
BLUE -12 V
RED +5 V
WHITE -5 V (May not be present on recently manufactured supplies)
BLACK GND
GREEN POWER-ON (Active high -- must be shorted to ground to force power up)
GRAY POWER-OK
PURPLE +5 V STANDBY
BROWN +3.3 V REMOTE SENSING
All I have to do is connect the black (GND) and the yellow (+12v) to my charger and I should be good to go. Being that I will be working with an ATX power supply I am going to need to ground the Green wire (POWER ON) to force it to turn on. And that is all? I will have a 12v 15a power supply?
thanks in advance!
Scott
ORANGE +3.3 V
YELLOW +12 V
BLUE -12 V
RED +5 V
BLACK GND
GRAY POWER-OK
PURPLE +5 V STANDBY
thanks in advance!
Scott
Actually the voltage drop is due to the fact you need to load the 5V bus to bump up the 12v bus. This is achieved via soldering resistor across the 5V bus. I've tried this experiment and it worked like a charm..... the 12V bus voltage increased from 10.5V to 12.5V. I have 2 made and charging at 6A is no big deal.
Bryan
Bryan
can you tell us was resistance reisitor u used??
cheers
wog
You can probably use a 3ohm resistor, 5-10 watt unit, could be had for about 25 cents at an electronics store, or a couple bucks at the source(radioshack). These are the large white resistors. As long as you got some load (1.5amps for say) out of the 5V line, the PS will crank out some current on the 12V line.
Even if the PS say 15A at 12V, don't get too happy!.. Most of these things don't put out as much current as they say it does. You either get a low voltage (voltage dips down to under 10V at a 5-7amp load despite a load on the 5V line) or it goes poof in a matter of seconds. They are cheap but not worth it in the long run....
