millenium pro or apex zero or ce pitbull?
which charger to get? going to be getting them 2nd hand and all three cost the same (about $100). thanks in advance!
any views/comments?
Do a search, maybe people are tired of aswering the same question over and over. There a lots of info to be found.
If you need to discharge funcion go with Apex Zero.
I have seen KO branding on this charger.
I would go for Pitbull if you only use it for charging.
I had a Millenium Pro and now have Pitbulls, never haerd of the 3rd one. The Pitbull is great, more adjustibility than a Turbo 35, never false peaks and has a long lockout.
i did search already and found only one person to give his opinion regarding the apex zero. thanks guys! are there different pitbull versions (like the millenium "ver 1.2 and pro")? am a newbie and will be buying a 2nd hand charger due to budget constraints. thanks!
The only difference between the two is that the PitBull Stealth has a black case versus the original's translucent blue. The Stealth also has the updated power supply wire harness, which has color coded ( black and red ) wire. The original pitbull had a smooth positive, and a ''ribbed'' negitive wire.
All the hardware is the same, it's just a cosmetic difference.
