Old 11-16-2007, 08:07 AM   #1
Default Motor maintenance
Hi, I could use some help on motor maintenance. By that I mean what should I do on a race day to race bassis with my motors. I am running brushed (stock usually). Not to sound rude or anything I do not want to hear anything about switching to brushless.
Any help or insites are appreciated.
SMOKESHOW86 is offline   Reply With Quote
Old 11-16-2007, 08:49 AM   #2
Oil and cut the motor and but new brushes on it if needed.
Shirk is offline   Reply With Quote
Old 11-16-2007, 09:07 AM   #3
QuickRC's Avatar
Between heats at the races it is a good idea to spray out your motor with motor cleaner - let the motor cool somewhat first. Lube the bushings (or bearings if not stock class) with a drop of oil and go race. If you are racing on-road then cleaning so often probably isn't a big deal but definately do it after each heat if racing off-road.
Between racing days I will pull the endbell and clean the comm and brush ends AND SIDES with a Trinity fiberglass bristle comm pen. That little pen works wonders between comm cuts. Every 3 or 4 race days I'll cut the comm and put in new or re-serrated brushes.
You can cut comm and replace brushes more or often depending on how much time you want to spend and how long you want your motor to last. I just race at the club level so I don't get too carried away with it.
Don't forget to take care of the batteries too.
QuickRC is offline   Reply With Quote
Old 11-16-2007, 09:44 AM   #4
Here's some great reading that should help you out. It's excerpts from Big Jims RC Motor Black Book...
bb71 is offline   Reply With Quote
motor maintenance rexvirtue Rookie Zone 9 06-30-2008 06:06 PM
Motor lot and motor maintenance setup - comm lathe, brush cutter, 27T, 19T, Mod jkas10 R/C Items: For Sale/Trade 5 06-10-2008 06:42 PM
19T Brushed Motor Maintenance Lot! Lathe, motor, spring thing, etc! Cain R/C Items: For Sale/Trade 0 09-11-2007 06:08 PM
Motor Maintenance dvdrsi Electric On-Road 14 02-08-2006 10:56 PM
motor maintenance bleach1 Nitro On-Road 0 02-22-2004 01:53 AM
SEO by vBSEO 3.5.0
