Old 05-31-2003, 02:14 PM   #1
Send a message via AIM to tdragon
Default Hpi Rs4 Pro3
i have a few questions about this car like is it a good car to race does ne 1 race these how do they preform? ne sugg for a diff car to race i will be racing on an oval asphalt track thanks
tdragon is offline   Reply With Quote
Old 05-31-2003, 05:01 PM   #2
Matt04's Avatar
i have a pro 3 and it is working fine, its fast it handles well and it is hard to break it(which is a good thing). i saw a guy using one in mod and it flys. its a great car and worth getting.
Matt04 is offline   Reply With Quote
Old 06-02-2003, 02:22 AM   #3
Accord's Avatar
Send a message via AIM to Accord
I have an Atsushi Hara edition Pro 3 for sale, if you don't know what that is, it's a stacked Pro 3 with everything you could ever want for racing.
Pro 3's stock out of the box, are well, horrible for racing. The Atsushi Hara edition Pro 3 is really the only good version of the Pro 3 for racing.
Check this out: Atsushi Hara edition Pro 3 - FOR SALE!
Accord is offline   Reply With Quote
Old 07-31-2003, 09:41 PM   #4
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
I need a baseline outdoor parking lot setup
trackdesigner71 is offline   Reply With Quote
Old 08-01-2003, 04:58 PM   #5
newracer's Avatar
R/C Tech Charter Subscriber
Default My current asphalt setup
Hop ups
PRP chassis and upper deck
aluminum motor brace
aluminum battery holder
heatsink motor plate
aluminum spur gear holder
aluminum pully mount
aluminum CVD's
graphite front and rear shock towers
Ti turnbuckles and hingepins
low friction belts
Xpress torque/camber rods
yellow springs/ 40wt oil, stock piston #3?
shock mounts-outer hole on bottom, lower inner on top
4 degree C-hubs
gold swaybar
camber link upper middle
-1 degrees camber
0 toe
lower arm mount- 2 degrees, I think?
ride height 5.5mm
blue springs/40wt oil, stock piston #3?
shock mounts-inner hole on bottom, outer top on top
0 degree hubs
silver swaybar
camber link upper hole on hub, inner middle on tower
-1 degrees camber
1-2-9 lower arm block
ride height 5.5mm
no one ways
HPI Mondeo body
Hitec DCX rx with 3D radio
Hitec 5925MG servo
Novak TC2, stock profile
XIIP tuned, P2K based motor with Putnam brushes and springs
Promatch 2400's
The track is 50x120, blown off and sprayed with sugar water
BTW I bumped up the old thread that has a lot of good info.
newracer is offline   Reply With Quote
Old 08-01-2003, 05:05 PM   #6
rc-zombies's Avatar
Isn't there a Pro3 forum already....?
Old 08-03-2003, 09:33 PM   #7
Speed Demon's Avatar
Default Trouble with my beloved Pro 3
I seem to be dumb about this...After servicing my car, it seems to have a problem that I tried to solve without success...
The car will oversteer when I turn left but good when I turn right..
All setting is good before I service the car.. I only clean the bearings, rebuild the shock and the diff.. diff are not too tight and not too loose...
Can anyone help me??
Speed Demon is offline   Reply With Quote
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 10:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 03:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 01:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 11:37 AM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 05:03 PM
SEO by vBSEO 3.5.0
