Old 06-04-2003, 03:42 PM   #31
I'm going to assume that you want PCM for the failsafe function, am I correct?
If so then turn to page 17 in your manual and you'll see that the failsafe is "AVAILABLE FOR Steering, Throttle, Channel 3, only with HRS/PCM receivers and HRS/PCM modulation settings "
What this means is that if you have a HRS Rx and set the MOD-MODE on the Tx to HRS then you can program in the failsafe desired.
AreCee is offline   Reply With Quote
Old 06-04-2003, 03:51 PM   #32
Accord's Avatar
Send a message via AIM to Accord
I already have the failsafe set for my radio in HRS mode, however I want the battery fail safe which I Cannot do unless i'm in PCM mode.
Accord is offline   Reply With Quote
Glitching electronics problem for a XXX-T crizo Electric Off-Road 4 05-28-2008 03:10 PM
Arcing/Glitching Problem 4x4xfar Monster Trucks 22 09-26-2005 06:56 AM
Glitching Problem TuxRacer Electric On-Road 28 11-13-2003 01:37 PM
Severe Glitching Problem - Please Help! Accord Electric On-Road 2 06-18-2003 01:44 AM
Glitching Problem JChan Electric On-Road 11 09-06-2001 09:40 AM
SEO by vBSEO 3.5.0
