Old 05-29-2003, 06:58 PM   #1
Default How do I protect the spur & pinion
gears from little rocks entering the hole under in the bottom of the chassis and also from under the body in the TC3?
RoadRat is offline   Reply With Quote
Old 05-29-2003, 07:19 PM   #2
Randy Caster's Avatar
Trader Rating: 45 (100%+)
You could make rock shields out of lexan... If you have a TC3, you should be running on a somewhat prepped surfice though to avoid that problem.
Old 05-29-2003, 07:31 PM   #3
Balak Racing's Avatar
Send a message via AIM to Balak Racing Send a message via Yahoo to Balak Racing
A simple piece of tape should fix that problem, but the best solution is to race on a surface that doesn't have a lot of little rocks
Balak Racing is offline   Reply With Quote
Old 05-29-2003, 07:55 PM   #4
WC's Avatar
Trader Rating: 28 (100%+)
I don't think those holes actually let in more dirt than they let out.
(not counting your offroad journeys though)
I find that more dirt is picked up by the front wheels and thrown
onto the chassis. Some chassis shields behind the wheels might
WC is offline   Reply With Quote
1/10 ep spur and pinion set up? pilipinas Electric On-Road 0 08-22-2008 04:27 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 06:08 AM
Big Pinion / Small Spur - OR- Small Pinion / Big Spur -- Difference? rctoyguy Electric On-Road 7 07-12-2004 04:54 PM
Spur or Pinion? Mossie Australian Racing 5 01-29-2004 06:46 PM
Spur - Pinion Combo KoE Electric On-Road 10 08-20-2003 07:54 PM
SEO by vBSEO 3.5.0
