Old 11-08-2007, 06:02 PM   #1
Default Schottky Diode
Can some one tell me what Schottky Diode does and whether it is were using for 1/12th scale stock.
Any help is appreciated
SMOKESHOW86 is offline   Reply With Quote
Old 11-08-2007, 08:40 PM   #2
A diode is essentially a one-way valve for electricity. What you probably saw it used for is polarization protection. Basically, so that if you accidentally connected your battery the wrong way, no current would flow, and your electronics would be protected. (Not all electronic components need polorization protection, it just depends on the parts.)
An inherent characteristic of a diode is that it will have a voltage drop across it when connected in series to a load (your motor/esc). Typical diodes have a 0.7V drop. This 0.7 voltage drop steals power away from your motor/esc. Instead of your motor/esc receiving 7.4V from your 2s lipo, it would only see 6.7V.
This is why you'd want to use a Shottky diode. A Shottky diode only has a 0.3V drop.
Hope this helps.
deskwarmer is offline   Reply With Quote
Schottky Diode?? aus jd 2703 Electric On-Road 38 06-30-2006 02:14 AM
schottky diode help JL Electric On-Road 3 08-27-2005 09:36 AM
Schottky diode for ESC danjoy25 Australian Racing 13 07-13-2005 11:12 PM
Schottky Diode YAHOO!!! Electric On-Road 2 03-04-2005 01:41 PM
schottky diode ????? drx Rookie Zone 2 04-29-2004 03:17 PM
SEO by vBSEO 3.5.0
