Old 11-08-2007, 01:13 PM   #1
Questions?? Deans ultraplug or Traxxas high current connector?
I wonder which of the Deans ultraplug and the Traxxas high current connector, delivers the most juice with the smallest loss(resistance)?
BrushlessT is offline   Reply With Quote
Old 11-08-2007, 04:10 PM   #2
hobbipro's Avatar
Trader Rating: 19 (100%+)
I cant tell you first hand, the Deans connector and Traxxas are virtually going to have the same low resistance. Both are constructed of gold plated posts that are very heavy, and both use the same spring type system to keep the connections solid. I'm a heavy Deans user, have been for years, and just recently soldered a set of TRX plugs on. I can tell you the pros and cons are:
Deans-smaller overall plug, can be reused, cannot be plugged in reverse, but can be a pain to solder if using heavy guage wire.
TRX- Extremely easy to solder to with heavy wire, cannot be plugged in backwards, a little larger than deans but no heat shrink is required, but connot be reused once assembled.
Its if though Traxxas took the deans plug and took the best of its features, and made it almost foolproof to solder them up and assemble correctly. They even took the extra step to put "wire side" and "A", or "B" markings on the posts and the actual housing for assembly purposes. I'd say it took more time for the iron to heat up than actually assembly time.
hobbipro is offline   Reply With Quote
Old 11-08-2007, 04:16 PM   #3
adamge's Avatar
6mm bullets:
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
adamge is offline   Reply With Quote
Old 11-09-2007, 12:26 AM   #4
I'm thinking Deans but the bullets seem nice too.
Thank you for your answers!
WTB: 1 Male Deans Connector andrewtexas123 R/C Items: Wanted to Buy 3 07-27-2007 01:44 PM
7.4 volt lipo 1700mah / deans connector / great 18th battery evostyle R/C Items: For Sale/Trade 10 05-28-2007 02:19 PM
high current charger MrUnlimited Electric On-Road 4 01-10-2006 08:48 AM
High current batteries BigBear Electric On-Road 10 03-24-2004 10:06 PM
trinity or deans connector? maxboost Electric On-Road 5 01-13-2003 11:00 PM
SEO by vBSEO 3.5.0
