Old 05-28-2003, 02:39 PM   #1
Default Gear Mesh on TC3....
How do I adjust the gear mesh (pinion and spur) on the TC3? It doesn't look like there is anyway to adjust it horizontally. Is the only adjustment the springed screw to move the motor clamp onto the bulkhead (vertical adjustment)?
RoadRat is offline   Reply With Quote
Old 05-28-2003, 03:04 PM   #2
CGR's Avatar
Loosen the screw over the spring, then move your motor until you get a mesh you like, then retighten the screw
CGR is offline   Reply With Quote
Old 05-29-2003, 10:59 AM   #3
mab_man20's Avatar
Send a message via AIM to mab_man20
To be a little more specific.
Place the motor in the slot, put the top brace over it and screw in the inside screw (not all the way, just so it grabs the nut a little). If you turn the motot towards the inside of the chassis you will notice that the motor moves horizontaly. There you go.
mab_man20 is offline   Reply With Quote
Old 05-29-2003, 11:36 AM   #4
In real simple terms: you adjust the mesh by ROTATING the motor either toward the spur gear or away from it. Then tighten the screws to hold the motor in place.
AreCee is offline   Reply With Quote
Proper Gear Mesh? ohmygahitscoby Nitro On-Road 6 05-19-2008 12:34 AM
About Gear Mesh bo_barger Nitro On-Road 2 03-29-2008 07:55 PM
help with gear mesh 2.5 tmaxx crashman105 R/C Tech Site Forum 0 09-22-2007 08:26 PM
gear mesh RebelRacer Rookie Zone 6 08-03-2004 06:45 PM
Gear Mesh JayBee Electric On-Road 12 05-15-2004 03:47 PM
SEO by vBSEO 3.5.0
