Old 10-31-2007, 07:58 PM   #1
amain's Avatar
Default check miah while charging with voltmeeter?
ok so i have a crapy a$$ dynmiate prophit for now till my new charger arrives. it has a volt meeter jack and i was told u can check the miah of what the battry is charging with therese jacks. my question is what setting on the voltmeeter do i use to check this?
amain is offline   Reply With Quote
Old 10-31-2007, 08:14 PM   #2
Use the 0-20 volt DC setting on most voltmeters or if you have automatic setting even better. You can monitor the voltage of the pack but not the MAH. If you have the time to watch the voltage climb as it charges you will know it is almost fully charged when the voltage stabilizes and after a minute or so the voltage starts to slightly drop make sure you stop charging when this starts to happen.
Hope this helps
jeffb is offline   Reply With Quote
Old 11-03-2007, 09:11 PM   #3
imjonah's Avatar
Default Also
The other sign your fully charged is temp increase.
If you get a cheap digital indoor/outdoor thermometer and use the the out door probe to monitor temperature, the point at which the voltage stops climbing you should see an increase in temperature up from room temp past 100 degrees F . Somewhere between 110 and 120 is the time to stop the charge.
imjonah is offline   Reply With Quote
Intellect IP3800 miah 25c ?? Ciny Electric On-Road 7 09-01-2008 01:11 AM
Charging Help Ferrarimk13 Electric On-Road 3 06-14-2008 02:41 PM
Charging help dgrobe2112 Electric Off-Road 1 11-24-2007 11:21 AM
Charging Li-PO A_380 Electric On-Road 23 10-10-2006 09:50 PM
Check out my Charging Station I built!!!! jamesbernatchez Electric Off-Road 2 08-26-2006 12:14 AM
SEO by vBSEO 3.5.0
