M-04 Opinions
#61
.......The biggest downfall with the M04, is dealing with changing traction levels on the track through the racing day. As the track grooves up and grip level increases, the M04 tends towards oversteer, which makes for a difficult drive. This can be solved with going to harder compound tires in the front, or using less traction compound on the front as the day progresses. Just follow the simple rule - "slide the front, stick the rear", and you will be fine. Get the rear end planted, and then slowly work towards increasing front grip to find a balance.
I do notice on dusty track, it spin out very very easily... So my latest RC inventories: 2 brooms(you can always find extra hands on track to chip in...) to swept the track....
#63
I've been used to running my M04 with GP3300's and 2400NiCD packs with no issues.
Now that I have a lipo pack that's 130g lighter, does it work just as well, or do I need to add weight?
I'm running it on carpet in a month, but have no time to practice at the track till the event.. Just want to be prepared.
