Old 10-28-2007, 10:06 PM   #1
Default Tamiya 1/10 scale shock spring specs
Hey all, does anyone have the dyno specs for the tamiya shocks? Tamiya seems to have amnesia and says this information is not available?
darrenthibodeau is offline   Reply With Quote
Old 10-28-2007, 10:20 PM   #2
linger's Avatar
Are you talking about the spring rates?
Try Tryhards website
I'd trust the measurements on the Tamiya spring since I did the measurements.
Also, keep in mind that the white coded springs on the milky blue and the all-white spring sets are STIFFER than the standard white spring - if you look at the coil count and diameter, it's pretty obvious.
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
1/8 onroad shock spring? Supraman93 Nitro On-Road 8 12-29-2007 01:40 PM
Spring Steel T Plate/Shock spring Question jnor Oval, Larger Scales and More 3 04-15-2007 02:12 AM
Shock Spring Dyno SpeedySST Electric On-Road 7 01-09-2007 03:14 PM
Tamiya flourine shock set & AE spring sets coolrcdad R/C Items: For Sale/Trade 1 12-26-2006 05:20 PM
Shock Spring Compatibility Tabushi Nitro On-Road 1 03-04-2005 01:58 PM
SEO by vBSEO 3.5.0
