Old 10-28-2007, 09:43 PM   #1
Satish's Avatar
Default APS Motor Dyno help
I recently purchased the S3 and am trying to figure out the best settings to start testing my motors.
I normally only use CO27's 19t will follow once I pick a motor.
So basically I want to know what Voltage do I start at - end at
what RPM is a good number for this motor (CO27)
out of the other numbers that are listed, AMP draw, elapsed time and Input voltage what is good or bad.
Thanks in advance for your help.
Satish is offline   Reply With Quote
Old 10-29-2007, 08:48 AM   #2
wingman2's Avatar
Hello mate, I have the original APS unit and have used it for a couple of years now with no problems at all. I only run 1/12th so I usually test the motor using the same voltage as the pack would give during a race, ie, 4.8v. I don't know if that's the correct way to test motors or not, but so long as the settings as the same for all the motors you test, at least you'll be able to decide which has the most rpm, curent draw, etc. Hope that helps a little!
Cheers, Chris.
wingman2 is offline   Reply With Quote
Old 10-29-2007, 09:03 AM   #3
Castradamus's Avatar
Trader Rating: 52 (100%+)
You should check out this thread
APS 3-in-1 Dyno Charge
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
SpeedzoneUSA.com | C&M Motorsports | TQ Wire | Team NAO | dIgItS pAiNt
Castradamus is offline   Reply With Quote
*** F/S: Motor Dyno - Integy Indi Dyno *** KenSmith R/C Items: For Sale/Trade 11 09-27-2007 06:53 AM
Integy Indi Dyno v2 motor dyno SpeedChair R/C Items: For Sale/Trade 4 08-14-2006 09:30 PM
Looking for a CE motor dyno AlanLim R/C Items: Wanted to Buy 0 08-25-2004 10:03 AM
Indi motor dyno vs. Orion Motor Perf monitor j240z Electric On-Road 5 08-07-2004 02:58 PM
Motor dyno Mad Mackem Australian Racing 9 05-26-2003 12:51 AM
SEO by vBSEO 3.5.0
