Motor fan wiring >
Motor fan wiring
Motor fan wiring
Old 05-23-2003, 07:22 PM
Claydoh's Avatar
Default Motor fan wiring
I've seen some mod racers with small fans attached to their motors. How are they wiring these? To the motor? I would think you'd want them to only run when the motor was to save juice. Anybody?
Claydoh is offline
Old 05-23-2003, 07:56 PM
Steevo's Avatar
Hi,
I am no expert in this field as I have never run a motor fan.
I would say that maybe you would run the power for the fan straight off the motor. This way it would only be getting power when the motor does.
Someone please correct me if I am being misleading...
Steevo
Steevo is offline
Old 05-23-2003, 08:08 PM
fatdoggy's Avatar
I don't think that orion motor is out yet, but I may be wrong. It would be very easy just to put a tiny reciever pack (maybe lithion) in the car with a small on/off switch. If you attached it to the motor you'd suck juice from the main power.
fatdoggy is offline
Old 05-23-2003, 09:32 PM
Boomer's Avatar
People that are doing that with the TC3 are finding that it doesn't suck very much power - especially if it's a small fan (all that will fit, really).
What they were doing was connecting the leads to the ESC's motor tabs. This way the fan was running fastest at full throttle (when it needed it) and wasn't wasting power when it was sitting still.
Boomer is offline
Old 05-25-2003, 11:44 PM
WC
WC's Avatar
Trader Rating: 28 (100%+)
What specs are these fans? 12V or less??
I borrowed a 2" one from a Pentium 1 cooler... but its rated at 12V. At 7V it doesn't like self-starting-up but if the blades are given a push, it'll spin up fine. At 12V it starts up itself fine.
WC is offline
