Old 10-26-2007, 12:22 PM   #1
Unhappy TC5 Ride Height
I am trying to set the ride height on my TC5 to 4.5mm for carpet. I am using 58mm dia. tires. I have the preload on the shock springs backed all the way off to the piont that they are actually loose. I still can not get the ride height to less than about 7mm. Are there any other adjustments I need to make to lower the chasis. (I am using the stock springs, red in the rear and copper up front).
frogman is offline   Reply With Quote
Old 10-26-2007, 01:09 PM   #2
Droop is a totally different adjustment, but if I have noticed if the screw is all the way backed out, that can create completly wrond ride height and droop. I have experienced this before, and if the droop if way off, it is hard to get the ride height set corectly. Your droop is probably off. That's just my take on these types of things.
samstheman2 is offline   Reply With Quote
Old 10-26-2007, 01:33 PM   #3
tcfree's Avatar
Hi, you should not ajust the ride hight using the droop screws 'if you do this it will now allow the shock's work correctley' Just depends @ where the droop is set @ now? i have not run foams with the tc5, but i would start with droop settings @ 7 front and 6 rear, you can also have the tire 'cut' down to achive the correct ride hight.
tcfree is offline   Reply With Quote
Old 10-26-2007, 02:30 PM   #4
Jack Smash's Avatar
Trader Rating: 28 (100%+)
If you adjust droop and it changes your ride height you are doing something wrong.
Jack Smash is offline   Reply With Quote
Old 10-26-2007, 02:37 PM   #5
tcfree his tires are cut down to 58mm already.
Old 11-01-2007, 02:44 PM   #6
Old 11-01-2007, 03:00 PM   #7
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I don't know how the shocks and sway bars mount on a TC5, but on some cars one could mistakenly mount the shock to the sway bar mount causing a super high rideheight.
|◤ReflexRacing.net◢|◤Gravity R/C◢|◤HWNA◢|◤AVID R/C◢|
Old 11-01-2007, 05:25 PM   #8
fathead's Avatar
I've had no trouble running 5.5mm ride height with 56mm foams.
Set the ride height using the shock collars first (they will prob be near the top of the shock at 4.5mm ride height), then set the droop (downtravel) with the droop screws.
The springs shouldn't come loose if you set the droop correctly.
Slavich Design
fathead is offline   Reply With Quote
Old 11-01-2007, 06:06 PM   #9
Trader Rating: 32 (100%+)
Send a message via AIM to Sean R
perhaps your shock ends are screwed onto the shaft too far. Try loosening them until you can get the rideheight down to around 3mm. This will allow you to set tweak, because it will give you some threads above the collar.
Sean R is offline   Reply With Quote
Old 11-03-2007, 09:22 PM   #10
swopemike's Avatar
You have to unscrew droop screws until they don't touch at full shock travel. Then set ride height. Then go back and set droop. Otherwise if you set ride height with droop screws already compressed you get "negative droop" (no droop) and spring preload which affects the effective spring rate (similar effect to using harder springs). You might do OK with no droop for carpet but you'll spin out on asphalt.
Carefully measure all 4 overall shock lengths fully extended. If all are even and car is balanced and not tweaked all the shock collar (or spacer) settings will be the same.
If you've done all this and ride height is still too high, then thread in the shock end (bottom) a little more, at least until there's no more threads showing on the threaded shock rod end. You should be able to easily set ride height down to 4.5mm with 58-60mm tires.
swopemike is offline   Reply With Quote
Old 12-02-2007, 04:41 PM   #11
If your shocks are backed off,back out your droop screws. Then adjust your ride highth first then set you droop. Ride for foams cut to 54mm we ride at 4.5mm to 5mm.(carpet)and droop at 1mm/front to 1.5mm/rear.Ride at 7mm to 8mm (asphalt/rubber) 10mm droop This works on our tc5
TC5-TC4-KSG-Tekin-Novak-3PK-Hitec-PRS-Gears-John's BSR-Racing-Tires Tri-State Raceway In Hamilton ,Ohio-Much More-Spektrum Associated-Team Magic-APS-SMC Competition Electronics-Ice.
8up-Club Dayton,Ohio
108% Certified 8up
8up-racing is offline   Reply With Quote
ride height QueBall727 Electric On-Road 9 07-14-2007 07:26 PM
Ride height ratter Electric On-Road 3 09-07-2004 05:16 AM
The right ride height FUK_WRX Electric On-Road 8 05-22-2004 11:11 AM
Wat is your ride height? DT-Skyline Electric On-Road 15 03-08-2004 10:00 PM
ride height nitroblade Nitro On-Road 7 04-17-2003 01:25 PM
SEO by vBSEO 3.5.0
