Tamiya mini cooper project >
Old 11-04-2007, 02:57 PM
Default Tamiya mini cooper project
My mini cooper(modified/brushless) took it's first run the other day and I was quite happy with the result. However after my 15min run the tires was almost totally worn down (it was the original tamiya tires). I wonder if anyone know of any good brand of tires for this car (or rc cars in general)?
If you are interested, watch the mini go on this adress:
http://www.youtube.com/watch?v=CwWqY71Og6Q
BrushlessT
BrushlessT is offline
Old 11-04-2007, 03:17 PM
the gimp. yeah the original tires wear out very quick, even with a stock motor. try the hpi x pattern.
slomo is offline
Old 11-04-2007, 03:30 PM
Ok, thank you!
I will check them out asap:-)
Is the traction(grip) better with the hpi x as well?
Old 11-04-2007, 03:35 PM
Burlap's Avatar
Check out the Mini Cooper thread for more info.
Link: http://www.rctech.net/forum/showthread.php?t=20068
Burlap is offline
Old 11-04-2007, 03:37 PM
Thank you!
Many useful tips on that thread!
Old 11-04-2007, 03:47 PM
rtherbe's Avatar
Nice video. That MiniGimper sure can move
rtherbe is offline
Old 11-04-2007, 03:59 PM
Default need help with m03
I HAVE JUST STARTED IN RC AND THIS WEEKEND WE HAD AN OVAL RACE
AND EVERYONE WAS MUCH FASTER THAN I WAS. I DONE THE WATER BREAK IN ON THE MOTOR AND PUT BALL BEARINGS IN PLACE OF BUSHINGS AND
OIL SHOCKS SO WHY ARE THE OTHERS SO MUCH FASTER.
SR901 is offline
Old 11-04-2007, 04:34 PM
gearing or battery?
slomo is offline
Old 11-05-2007, 05:18 PM
I AM NOT SURE IF THE MOTORS THAT COME WITH THE KIT ARE DIFFERENT
OR NOT BUT IT SPINS REAL EASY SO I BOUGHT A NEW MOTOR AND DONE THE SAME WATER BREAK IN AND IT SEEMS TO BE ALOT HARDER TO SPIN.
THIS COULD HAVE BEEN THE PROBLEM RIGHT.
SR901 is offline
Old 11-06-2007, 12:59 AM
caps lock means YOURE SHOUTING!
slomo is offline
Old 11-06-2007, 08:21 AM
SirSwiftAlot's Avatar
Location: SOCAL the fastest mini cooper guys in the nation
Go to Silver Can Motor Tips/Tricks on the electric on road forum side and do your research there is about everything you need to know right there. If you have any questions just post one and look at the amount of feed back you get. Just remember read first then ask questions. Theres about 16 pages but its well worth it.
SirSwiftAlot is offline
Old 11-06-2007, 05:04 PM
chris72983's Avatar
Here is a link to thread mentioned above. http://www.rctech.net/forum/showthread.php?t=104289
chris72983 is offline
Old 11-08-2007, 06:36 PM
thanks,that thread done the trick
SR901 is offline
