T*Star12
#16
TurboT
"I actually like the solid chassis"
Me to but what can we do, the battery and the motors are getting
more heavy every time they release a new battery or motor
today it is 59 gram, the GenX is 49 gram
30 gram will be the dream :-)
I hop to get in down to 44 gram
Alf :-)
Alf :-)
#17
Alf,
I see you are trying to remove weight and that is cool but be careful how you achieve that. Excessive pocketing can hurt the chassis plate by causing it to buckle or potato chip. The reason for this is due to the construction of carbon fiber. All of the layers are mirrored off of the center so what will happen is you will remove stress from one side of the center only and this can create a bow. The best way i have found to remove weight it starting from the highest point on the car and moving down. Hope this helps buddy.
#20
Thanks great! to get fed back on this
protc3, Jason
If i'm getting you right, you mean i have to cut through
the chassis right ?
Pro ten Holland
If i do it on the top, it will create a problem
with Somme ESC, since you will have to leave some off the carbon fiber
and then you will have problems mount it
well if every body are using the same electronics then
this can be done, but what Jason pointed out doing pocketing this are
probably not a solution.
This got me thinking off Somme off my Windsurfing skills, wen i made some fins
if i make a mold i will be abel to make it strong were it have to be and light
i talking about the sandwich construction used in windsurfing boards
a High density form, then it will be possible to make the chassis
with out any cutout but inside it will be a mix off carbon fiber and foam
Alf :-)
protc3, Jason
the chassis right ?
Pro ten Holland
Alf :-)
#22
protc3, Jason
the chassis right ?
Pro ten Holland
Alf :-)
protc3, Jason
the chassis right ?
Pro ten Holland
Alf :-)
You should give DA Graphite a call. He has a material similar to what you speak of and the price is alot less than standard carbon fiber.
What i was saying about the pocketing is not to go to crazy with it. You can do some but try not to break into many through pockets or walls and dont do alot of large areas. THe chassis starts to bow.
#24
#25
Pro ten Holland
protc3
I will give he a call
AdrianM
Giorgio
A very old version off Solidworks
What about drilling a lot off holes ?
Alf :-)
protc3
AdrianM
Giorgio
Alf :-)
#26
Alf
I've asked because I just move from 2D (Acad Mech Desk) to 3D (SolidEdge). In my past I've drawn several machines (f1 and Touring chassis upgrades).
I would have removed a bit of material under the front end. You have already the nylon/derlin items, you don't need all the material there.
Instead of pocketed area, try to find some area where you will put the electronics and remove (hole) the area below.
Excellent job.
Ciao
Giorgio
Excellent job.
Ciao
Giorgio
#27
Way to go Alf, the car looks good
#28
HappyHippo
In case anyone wonders what i'm doing, i center the servo
before setting the to out, i have made a center hole for this, but i have to make
some sort of a pin to use it.This for centering the servo perfect.
What about this ?
Will be very strong and not cut through, drilling 2.25 mm chassis is 2.5 mm
Alf :-)
What about this ?
Alf :-)
#29
I think that this can work
have any ever try this ?
Alf :-)
Alf :-)
#30
Hi,
when creating holes and gaps to make things lighter you should
be thinking in lines between points of stress.
Connect the ponts or holes that support components
en greate gaps between those lines.
You also should be aware of the post stamp effect.
It is easy to break somthing when holes line up.
I realy like your effort to continue the 1:12 evolution.
For a few months I own and drive a 1:12 car but got
already som ideas for a simpeler concept.
In 1:10 touringcars it is a great benefit to move the battery as much to center as possible.
I assum that is the same with 1:12.
In the concept i am thinking of,
the battery will be placed as 4 cells in the middle of the car,
and the T-bar placed to the outside of the car.
Anyway this winter I wil make some prototypes to test on the track.
