Old 05-20-2003, 09:27 PM   #1
Default Hudy part number???
I have been told that there is a new arbor for the hudy tire truers that will allow you to mount both TRC and Jaco wheels (12th scale). Can someone that is using this please give me the part number. I have the old one i can mount the 3 hole Jaco rear and the jaco fronts but can't mount the TRC wheels. Thanks for your help
Joneser is offline   Reply With Quote
Old 05-21-2003, 06:33 AM   #2
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
I have the new one and it still doesn't do Jaco fronts.
It will do TRC and the new CRC wheels with no problem.
Jaco rears fit fine, just no fronts....
the web in the middle needs to cut down....
Part # HUDY102374
old one was HUDY102372
Tres is offline   Reply With Quote
Old 05-21-2003, 11:49 AM   #3
Trader Rating: 30 (100%+)
I use a 15/64 drill bit to hand ream the center webbing of Jaco fronts to fit my hudy arbor....still a tight fit but it works.
Lowrance is offline   Reply With Quote
Old 05-21-2003, 02:13 PM   #4
Default Thanks
Tres....thanks for the help....I usually ream the ribs on the jaco's down to fit on my current arbor. THe problem I was having was with the TRC wheels. I will be hooking up with you soon for a faceplate for the GFX as soon as I figure what I want.
Tres....do you have the ability to take a picture or two of the arbor. I cant find one and I want to make sure that it is correct. Do you know how long this has been available. The reason i ask is that I was on MYTSN.com and there was now pic for that part number and it said the page was modified in 2000. I was assuming that this was newer than that
Need help with part number litsluv Electric On-Road 2 12-28-2006 08:53 AM
i need part number to this hitec part TomB Electric On-Road 2 05-23-2006 07:58 AM
what part number???????? Lst Quad Monster Trucks 0 11-04-2004 09:32 PM
Part Number for an MR-12 Dust Nitro On-Road 0 07-11-2003 03:22 PM
ANyone have the part number... RedScorp Nitro On-Road 1 05-03-2003 03:24 PM
SEO by vBSEO 3.5.0
