Old 10-05-2007, 08:37 AM   #1
Default Common Sense RC Cellspy
Our new Cell Spy is a useful tool for checking the charge/balance status of your Llipo packs. It's available in the "Accessories" section of our website.
The Cell Spy plugs into any standard 2.5mm-spacing balance connector and reads out the individaul voltages of the cells. If any of them are below 3.3V, you'll know to swap packs before you fly again.
Common Sense RC
The Go-To Guys in Electric Power
Common Sense RC is offline   Reply With Quote
Old 10-05-2007, 11:25 AM   #2
bxpitbull's Avatar
Nice invention. Question, can the minimum voltage be adjusted (say, each cell to 3 volts?). Also, does it act like a drag break when on throttle? Cellshield has a product (piece of junk) that is similar to yours....but, when on throttle for more than 3 seconds, kicks in drag break and limits voltage output!
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Common Sense LVC Problem RCRat Electric Off-Road 0 08-25-2008 10:34 PM
Common Sense RC regulator dsl Nitro Off-Road 7 03-11-2008 08:28 AM
Common Sense RC Balance Adapters Common Sense RC Electric On-Road 1 10-19-2007 01:40 PM
2C Charging of Common Sense RC Packs Common Sense RC Electric On-Road 2 10-11-2007 11:47 AM
R.I.P. Common Sense Kraig Chat Lounge 16 09-08-2007 05:34 PM
SEO by vBSEO 3.5.0
