Help! My Rooster is a Chicken!
Hey guys, I need some advice. I have just brought a brand new
Novak Rooster 12t esc. I fitted to my car, set it up as per
the instructions. I goes forward and reverse as normal, but then
after running it for a little the car stops. Wait about 5 seconds
and away it goes again, then it happens all over again. All the
red and green lights work as they should, I still have steering
etc. When I fit my Futaba mc330cr esc it works like clockwork,
doesnt miss a beat.
Any ideas???
doesnt miss a beat.
Any ideas???
the rooster may be fitted with low voltage cutoff..
nimhs cant hold the voltage like lipo can..
when you take off. you might bring your six cell pack down to five volts. which is too low for a normal lipo pack. where as when you take off with a lipo pack its much more efficient. and can keep the voltage up while providing the power at the same time.
kinda like haveing a really good matched pack with low internal resistance..
sorry for not making sense..
can somone explain the whole nimh vs lipo voltage drop thing
check to see if low voltage cutoff is on
.... EDIT.....see i had a feeling it had low voltage cutoff
direct from novaks site
When the original Rooster debuted way back in 1993, it was Novak’s first ESC with the now standard One-Touch Set-Up feature. The new Rooster 12T has the honor of being first again with another great new feature: built-in Li-Po cutoff protection. Novak’s newest technology monitors the vehicle’s Lithium Polymer battery pack’s voltage, and prevents the batteries from going below the critical safety voltage level. The driver is cued via throttle blips when the voltage drops to a certain level. It then shuts off, however, full control of the steering servo is left intact. The Li-Po cutoff protection feature can be utilized in two of the four throttle profiles the Rooster 12T now has:
Tech Legend
Trader Rating: 51 (100%+)
When I used them I dyed mine black and it got faster. It worked so good in the lates 80's the everyone was doing it.
Well I think its fixed. After triple checking everything to make
sure it was correctly installed, I ended up removing the rz motor
and soldering on the two extra capacitors onto the motor, from
the negative to the can, and from the positive to the can (including
the one from positive to negative).
I then reset the esc and ran the car, it behaved alot better, but
after around two minutes it played up again. So in all dispare I
removed the factory fitted capacitor from the rz and run it again.
I have now run two intellect 4200mah batt packs through it until
they dumped, and it has performed perfectly. Lets hope it stays
this way. Thank you guys for all of your tips!!
