Old 10-01-2007, 02:12 PM   #1
Renuco612's Avatar
Send a message via AIM to Renuco612
Default Sealing Chassis!!
I was wondering how some of you guys seal your Graphite Chassis? I tried the whole super glue method but mine came all funky looking.I see some guys chassis and their looks like there mirrors all around them. I know there is a way to do it without the glue, so how is it done?
Can someone post some pictures of your chassis so I can get a good idea of what to and how to do it? I am going to install my new ITF chassis on my TC5 but I know I need to seal it first so I want to do it the right way. Not like how I did it with my Stock Chassis.
Futaba 3pk
LRP Sphere Competition TC
Futaba S9550
Orion 3200 Carbon
Renuco612 is offline   Reply With Quote
Old 10-01-2007, 02:16 PM   #2
Trader Rating: 56 (100%+)
Send a message via AIM to joey
check this thread out it helped me a few weeks ago when i had to seal a chassis...
HOW TO: perfect carbon fibre edges
=Joe Wright=
joey is offline   Reply With Quote
Old 10-01-2007, 03:22 PM   #3
Well if you don't use glue it isn't really sealing the edge it's just sanding it. The glue penetrates the edge of the graphite just a little bit to help keep the layers from seperating under impact.
That's a great write up BTW
Old 10-01-2007, 03:36 PM   #4
wallyedmonds's Avatar
i dont bother doing this anymore
takes to much time and im lazy and iv never hade a chassis split and if i did do that big of a crash id just change the chassis coz its probably messed up anyway.
i sand it a little for the batts and around the chassis just so its not so sharp.
wallyedmonds is offline   Reply With Quote
Old 10-01-2007, 03:44 PM   #5
today's graphite is of much higher quality then when I first started. The weave is nice and tight and the layers super condensed. It's probably not near as necessary as when the practice first started years ago.
Old 10-01-2007, 03:51 PM   #6
Branden Moody's Avatar
I use a q tip and put super glue on it ive messed up chassis before buy trying to run a bead of glue along and ive found thaat this works best and it idoit proof for people like me. Just try not to gut the smoke coming off of the qtip in your eyes its pretty potent. good luck
Branden Moody is offline   Reply With Quote
Old 10-01-2007, 04:04 PM   #7
ooliganRC's Avatar
Send a message via MSN to ooliganRC
what i do is.
1. sand edges round using sandpaper....
2. clean with motor cleaner
3. using a permanent marker black edge the carbon and allow it to dry.
4. using q tip apply runny superglue in light coats.
dont use thick superglue it goes crappy.. runny tyre glue is best
ooliganRC is offline   Reply With Quote
chassis sealing tutorial nemix Rookie Zone 4 04-28-2008 04:28 AM
Sealing a Chassis CREWMAN Electric On-Road 5 02-10-2008 11:02 PM
Sealing your engine? razor_clawzz Malaysian R/C Racers 2 01-27-2008 05:51 PM
Engine Sealing SPZA Electric Off-Road 2 03-24-2006 07:57 PM
Sealing an Engine rcfoolz Nitro On-Road 10 01-28-2005 11:17 AM
SEO by vBSEO 3.5.0
