Which High End Speed Controller Is the BEST??
Hi DuDes
Our Club allows reversible speed controller and I'm using nosram power missile reverse...yesterday I've checked some technical specs and saw an huge gap between reversible and not reversible speedos...
I've got GT7 indoors but IT's huge
Could you recommend me a good overall speed controller or do you think it's better to stay with reversible speedo ?
Many thanx in advanced
Well, tbh if you feel you can do without reverse and dont crash much, imho I would use a forward only esc, if you feel you still need reverse the question answers itself.
Dont want to point out the obvious, but it really depends on how you feel you can cope without the reverse.
As you say, there is a difference in specs of reversed and non reverse esc's, but unless you are very consistant with laptimes its unlikely you will notice a huge difference.
hope that helps you
hope that helps you
ESC's
Get rid of the reverse
The best speed controls (IMO) are the Novak GTX and the KO VFS-1 C2. There is also the LRP Quantum Comp III, but personally I haven't had good luck with LRP products.
I was at the A final last meeting i've done 26 laps crashed max 5 times...
most of the people using forward only but some times it's not easy to trust marshals I'm a bit confused about what to do
look into keyence rapida pro ,,,, really smooth esc and has tons features and adjustments for different profiles not like the gtx it says HELLO to you when you turn it on
As others have also mentioned that in some other professional league racing reverse isnt allowed, (imho) I would be inclined to buy a better esc that doesnt have reverse, it will kinda teach you not to crash first, knowing in the back of your mind you no longer have reverse.
That in itself can only be a good thing!
Thanx guys
I may go for MRT MX pro...
Is there anyone using them here?
cheers
cheers
Yes, I've been using the MRT Pro for nearly two years now and they are fantastic. Good pre-set adjustmetns on it for stock,19T and mod motors and it is guaranteed water-proof if you run outdoors.
Service from the company, if you need it, is apparently great too so I'd recommend this controller every time. Best one I've had in 25+ years of racing.
Just keep using what you got until you don't crash any more most races. You should eventually be able to run a clean race, no marshalling, then the forward only ESC will be worth the money to you. Until then save your cash for something else you have to have, like food, clothing, tires, race fees, practice fees, etc....
thanx fellas bset bet is to wait another couple of weeks and go for MRT
I'll try to find a used one...It's not easy to find Tekin products in UK also I've checked for some pics they all looks like a photoshop stuff I don't know why...
GTB You can't go wrong with orange.
I got word-up that the mrt speedo won the national stock series over the pond on home ground....I'm waiting for mine to turn up
