motor and pinion help (TC4 HELP PLEASE)
recommend for this motor?
link to the motor
http://teamorion.com/Products/Motors...petition+Stock
i have a 27tooth pinion, 28 tooth, 25tooth, 18tooth and a 22tooth. i can buy more if needed.
link to the motor
This is 27 turn motor so use your largest pinion. If the motor heats up too much use smaller pinion.
The manual for the car should give you recomendations for 27 turn motors.
link to the motor
link to the motor
link to the motor
link to the motor
I am assuming your running 48P. What worked best for me was a 25/72 at our LHS, but having said that the track layout and motor temp made final gearing choices. Tight courses it ended up being 23/72 and motor temp at the end of 5 minutes was around 135-150 F.
I have since switched over to 64P in both my sons as well as my car. Right now my car is set up with 33/94 and is is 32/100. His motor temp is higher than mine by 10 degrees. Both motors have been "tweaked".
