Like Tree6Likes
Old 02-15-2004, 01:54 AM   #1456
Hi all.
Im new to this forum but I got my PRO 4 on Friday and spent till now building it. I have found the kit to go together very well. Did all shimming as manual and the drive seems very free and smooth. I also tapped all holes first.
The only problem I had was when I come to put some wheels on the rear they were catching on the upper link and the lower shock mount (both done to manual setting). I tried HPI foam, Orion Frsh kicks and schumacker 24 dish wheels wiyth sorex rubber. The fresh kicks cleared the upper lick but hit the shock mount and the other two hit both. The only way I could get aound this was to move the shock in one hole and snad the round part of the ball cup off with a rotary tool.
If any body else has add this problem please say.
Just looking forward to getting the car on my local club carpet track on tuesday.
Steve B is offline   Reply With Quote
Old 02-15-2004, 03:24 AM   #1457
big_G's Avatar
R/C Tech Charter Subscriber
Originally posted by Steve B
Hi all.
Did you add the washers behind the wheel hexes?
I haven't had this problem.
big_G is offline   Reply With Quote
Old 02-15-2004, 04:24 AM   #1458
Hi big_G
I have use the 1mm & 0.5mm spacer after the hex and 2 x 0.2mm shims between the bearing and pin.
If I use more spacers the nut will not go fully on the shaft.
One question though what is th inside diameter of your wheels when measured from the back. My HPI foam, Scumacher wheels are 45mm & Orion fresh kicks 47mm.
Old 02-15-2004, 04:48 AM   #1459
snoopy's Avatar
Originally posted by racer
have a question for all you experts out there!
if the car is slugish while moving from chicane to chicane. what should i do? change the springs?
someone at my track suggested getting softer springs for the front?
btw. i use rubber on carpet
any input would be appreciated.
Thanks!
To make the car more responsive you need to stiffen up the car...
You can stiffen the chassis by using the optional chassis brace supplied in the kit as a start. Then work on stiffening the suspension.
The car is very well balanced out of box, so stiffening both front and rear by the similar amounts will give you a similar balance while making the car more responsive.
snoopy is offline   Reply With Quote
Old 02-15-2004, 08:29 AM   #1460
Nothing was very hot (batteries or charger), but I know the cells are fried after hooking them up to my ESC. I guess I'll try to return it to Orion, not sure how that works since they are in Switzerland and I bought the charger from Sheldon Hobbies (and the digtal discharger - does it suck too?). Some of the battery juice got on the metal side of the charger and ate away the bits of paint. Anyway, does anyone have a suggestion for a good AC/DC charger? Or even just a DC one - I've got a 12V power supply coming in the mail.
Thanks for the heads up on the charger!
jleibund
jleibund is offline   Reply With Quote
Old 02-15-2004, 08:58 AM   #1461
pucho's Avatar
Send a message via AIM to pucho
lrp pulsar
pucho is offline   Reply With Quote
Old 02-15-2004, 09:07 AM   #1462
popsracer's Avatar
any input would be appreciated, Thanks!
To improve transitional reponse (left to right) you need to go with heavier Shock Oil. This applies to any Car. Try going up 5-10wt at both ends of the Car untill you find the response that you are happy with.
If the car is rolling too much in the corners, then also change to heavier springs.
popsracer is offline   Reply With Quote
Old 02-15-2004, 09:13 AM   #1463
Trader Rating: 14 (100%+)
Pucho:
Hi,
Are You home???????????? need some help with my "other car".
no Pro 4 as we are getting ready for karting......looks like Mini might be running two classes this year. looks like ICA is in our future. (water cooled nonshifter) and the KT 100.
I'll try to call a little later
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 02-15-2004, 12:02 PM   #1464
racer's Avatar
cool, Thank you popsracer and others for your input on the situation. i'll give it a try!
Old 02-15-2004, 01:52 PM   #1465
Erik Shauver's Avatar
Erik Shauver is offline   Reply With Quote
Old 02-15-2004, 02:13 PM   #1466
pucho's Avatar
Tim I just got home. I just sent you an email.
Luis
Old 02-15-2004, 02:15 PM   #1467
All of this waiting is intolerable. I think I've read through the manual about a billion times by now!
Old 02-15-2004, 02:33 PM   #1468
Old 02-15-2004, 03:51 PM   #1469
Take a picture if you can so we can help you out.
Plus The foams are HPI 26mm.[IMG]
(Thanks for the tip)
Old 02-15-2004, 03:54 PM   #1470
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
you can only attach one picture at a time.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
