Like Tree5Likes
Old 07-08-2006, 12:00 AM   #14491
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by rc-zombies
2mm hex
5.5mm nut driver
7.0mm nut driver for the wheel nuts.
+1.5mm hex for set screws.
floodo1 is offline   Reply With Quote
Old 07-08-2006, 02:22 AM   #14492
Default help
thanks guys for the info
LORD SHADO is offline   Reply With Quote
Old 07-18-2006, 10:35 PM   #14493
raptor 700's Avatar
How can I get steering from the center to exit of the corner with it being to responeive? thanks
raptor 700 is offline   Reply With Quote
Old 07-21-2006, 09:30 PM   #14494
Oasis's Avatar
Trader Rating: 36 (100%+)
I'm trying my 2mm chassis out tomorrow and was wondering should I go to softer springs or stiffer springs? I'm running stock, parking lot track, medium traction. I was thinking I should run a bit stiffer set up due to a bit more flex in the chassis but I'm not sure. I have tried that with a TC4 (tub chassis) and ended up going to a softer set up..
Oasis is offline   Reply With Quote
Old 07-21-2006, 11:04 PM   #14495
rc-zombies's Avatar
try Hara's 04 Roar Nats set-up... great starting point.
Old 07-23-2006, 03:15 PM   #14496
GreaseMonkey's Avatar
Hi people,
I recently came into the ownership of a Pro 4. It has BMI upper deck, lower deck and strut towers, TC3 axles, aluminium camber plates and possibly a few other things I don't know about.
I'll be running on carpet and initially I'll be running 4 cell stock on rubber till I get used to the car.
Are the nany recommended hop-up I shound have?
Thanks.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 07-23-2006, 05:51 PM   #14497
Oasis's Avatar
Originally Posted by GreaseMonkey
Hi people,
Thanks.
Sounds like you already have the ones you need, I ran a Pro4 on carpet and found it to be very capable car, Run a diff up front, A spool and one way don't seem to hold up very well on carpet.. Run the sway bars front and rear, If your running stock rubber tires don't go to a stiff set up (like you would do on foam) I would try gold springs in the rear with 50wt and #3 pistons with the 1.6 sway bar, for the front, white springs with 50wt and #3 pistons. Stick with the 4 deg. hubs (seems to give the best entry and exit steering) I ran the shocks in the #2 spot on the tower and the #2 hole on the A arms. I ran the ride height at 5mm in the front and 5.5mm in the rear. Some tracks wont let you run any lower than 5mm..It tears up the carpet if you run much lower..Good Luck
Old 07-23-2006, 06:36 PM   #14498
Thanks for the reply. Not sure what you meant by stock rubber tyres. I'll be runnig CS-22s. Oh and my LHS didn't have Pro 4 springs in stock but they did have losi springs that happen to be 25x13 so I bought a set of them so your colours might be off. (I'm sure I can find a spring comparison sheet somewhere on the net). As for the rest of the car it looks like it's already set up to what you recommend.
Thanks again.
Old 07-23-2006, 07:18 PM   #14499
Oasis's Avatar
22's man that's a soft tire.. Is that a control tire? By that I mean do you have to run that tire..If not I would run a CS27. I guess you would know what tire you would need for your track..But I know that for the CRC carpet I was running pit (brand name) 30's with the same set up. On the springs an HPI white spring is rated at 20.3 and the gold's are rated at 19.0. From what I have seen the Losi springs do not cross over very well..They don't seem to have the spring rates you need, Either to soft or to stiff not much in the middle. I would look at the associated or Yokomo /rayspeed.
Old 07-23-2006, 08:37 PM   #14500
kewdawg's Avatar
Thanks again.
You can use Xray springs. They fit just, as well as, Hpi springs. Why 4 cell stock? That's gotta' be really slow!
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-23-2006, 08:56 PM   #14501
Well, I'm just getting into racing (I've bashed for about a year) and the starting class at my local track is 4 cell stock with rubber. I figure i'll start there and work my way up. At the moment it's the quiet season so a good time to learn. I probably won't race till the fall, just practice for now.
Old 07-24-2006, 01:30 AM   #14502
rays_tt's Avatar
Trader Rating: 26 (100%+)
hey guys just got my pro4 and just wna race it in 540 for the time being to get some practice under the belt, whats the perfect ratio for 540 on the pro4?
Thanks.
www.melbRC.org
rays_tt is offline   Reply With Quote
Old 07-24-2006, 01:40 AM   #14503
rush evo dude's Avatar
Send a message via MSN to rush evo dude Send a message via Yahoo to rush evo dude
wow! looks nice!
i would like something like that.
so is it 2 or 4wd?
i have a kyosho chassis that's 4wd.
what's better, 2 or 4?
thanks
Rush evo dude
P.S. sorry for the questions
rush evo dude is offline   Reply With Quote
Old 07-24-2006, 02:17 AM   #14504
Nicadrauspro4's Avatar
Good luck on your new Pro4 guys. Enjoy it. Happy racing!
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 07-24-2006, 04:40 AM   #14505
Essnowyt's Avatar
Send a message via AIM to Essnowyt
GreaseMonkey & XXXKat - PM me I have a set up you might like to try.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
