Like Tree6Likes
Old 04-17-2006, 12:20 PM   #14266
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by LORD SHADO
Motor Lathe , whats a good one?
Hudy makes one of the best. I'm sure Integy has a good knock off of one though
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-18-2006, 02:22 PM   #14267
junbantay's Avatar
Originally Posted by movingparts
Guys! Just had my pro4 from my uncle...
I'm just wondering..how do you balance it, It wont go straight run..youll have to control it because it always turns from the right..My best guess is, my battery is more heavier..
Thanks Guys!
Mike
hehe if you are turning to the Right then its not your batts... cause Pro4 batts are on the Left side. most likely your wheels are not Cambered and Toe'd correctly Plus your servo is probable to be not on Zero with your Controler... try have someone Camber it for you in your regular Shop and then ask if they can Zero the Streering for you... Its difficult to Zero the steering if you have no proper equipment for the Cambering.
junbantay is offline   Reply With Quote
Old 04-18-2006, 02:38 PM   #14268
junbantay's Avatar
These are Pics of what I did to my Pro4. I sliced the whole Length of the Top Deck into 2 peices so giving it more Flex. I dont Use the Middle Stiffiner that holds the upper and lower Decks ( I have no Place for it Anymore, as I have Splitted the Upper Deck that holds the Top part of it. hehe )
I have also Bored a rectangular Slot on the Front side of the Chassis.
I also shaved the Aluminum Shaft to my Content...
Oh well.... its up to you to experiment on your Kit. I did what I like and it works for me. It Got me a Trophy on the Nationals in Cebu for that Setup.
Or Maybe its my Driving?..... hehehehe Joke!
Cheers!
Honestly.... this radical modifications makes or breaks the next generation of Kits... should the manufacturer's find out its a good thing.
For me... I just liked it...
Hpi Pro 4-63e80009.jpg   Hpi Pro 4-63e80010.jpg   Hpi Pro 4-63e80011.jpg   Hpi Pro 4-63e80013.jpg   Hpi Pro 4-63e80016.jpg
Old 04-18-2006, 03:56 PM   #14269
AngryAsian's Avatar
Wow!// big mod...
what did you cut the CF with? It looks pretty even in those small pics. Do we get any larger detail? Is that a Hara top-deck that you've modded?
How thick is the CF.. standard chassis?
well done!
AngryAsian is offline   Reply With Quote
Old 04-19-2006, 08:40 AM   #14270
rc-zombies's Avatar
here's something I came across on RcMart:
Spool adapter that fits the one-way unit.
Old 04-19-2006, 08:50 AM   #14271
dstyles's Avatar
so, that should give you the 'spool' action on power and the off power one-way action without the individual tire roll?
dstyles is offline   Reply With Quote
Old 04-19-2006, 08:51 AM   #14272
rc-zombies's Avatar
maybe...
don't have one to try yet...
found it on ebay as well...
Old 04-19-2006, 04:47 PM   #14273
josh69162's Avatar
Send a message via AIM to josh69162
It should just give you the rear (but straighter) breaking of a oneway, but you maintain the turn-in of a spool.
-Josh
josh69162 is offline   Reply With Quote
Old 04-19-2006, 04:52 PM   #14274
AngryAsian's Avatar
I'm not so sure that's relaly all that useful yeah?
Locking your one-way so that you lose brakes (one of the biggest advantages of using a spool in the first place), but losing one-way action for turn-in?
Spoosl have horrendous initial turn-in(off power). It's exit steering that they excel at. Which... er.. is basically the same as a one-way anyway which if for all purposes and intents "locked" in drive on corner exit. So there's not much to be gained right??
A one-way gives you initial steering because it allows the outside wheel to track faster, to complete its traciton circle. A spool means the both front tires are rotating slower than they would, if they could complete their own traction circles...
I'm not too sure i understand WHY... lol!!
anyone care to enlighten me?
Old 04-19-2006, 05:03 PM   #14275
bhambrent's Avatar
Hey guys,
Do any of you know the parts# for the pro4 motor mount?
Thanks,
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 04-19-2006, 05:05 PM   #14276
AngryAsian's Avatar
Old 04-19-2006, 05:26 PM   #14277
Send a message via Yahoo to nomaak
hmmmm...i might have to check into one of those!
nomaak is offline   Reply With Quote
Old 04-19-2006, 05:40 PM   #14278
anthony390's Avatar
Send a message via AIM to anthony390
yea angry asian gots it
i think the name of the item is just misnamed because it doesnt do anything good for the one-way in traction of the circle nor is it better than a spool in braking
if it really does DO somthing tell us
anthony390 is offline   Reply With Quote
Old 04-19-2006, 09:07 PM   #14279
Trader Rating: 195 (99%+)
Who makes the best spool? And any install advise on a spool?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 04-19-2006, 09:34 PM   #14280
AngryAsian's Avatar
The HPI unit is nice and light, but because it's all aluminium it does wear out quite quickly.
TiR do a nice unit with either replaceable delrin outdrives, or a steel version. Both look good to me, but i've never used them.
Shooter came out with one a while back too but i've not seen them around locally.
As for advice, make sure everything is shimmed well. If you have old style diff gears lying around then buy the alu reenforcing plate to avoid chipping teeth. The new 1.1v gears are much stronger. I'v enot had a problem with them.
