Old 02-11-2004, 12:17 PM   #1396
Send a message via AIM to True R/C Racing
my friend ran.... Copper rear dont know fronts Maybe copper all around
True R/C Racing is offline   Reply With Quote
Old 02-11-2004, 12:22 PM   #1397
rc-zombies's Avatar
Originally posted by bob szeto
Hi, can anyone help what kinds of spring would you prefer for the Pro4, if I'm running stock.
Thanks.
The stock springs work fine.....
Old 02-11-2004, 12:26 PM   #1398
bob szeto's Avatar
Thanks,
Is that the old HPI copper spring? Do you have the parts # for it?
bob szeto is offline   Reply With Quote
Old 02-11-2004, 12:26 PM   #1399
nope i think its stock though
Old 02-11-2004, 04:12 PM   #1400
racer's Avatar
Originally posted by rc-zombies
The original ball cups are different from other HPI kit...so don't know how they will hold up... I'll keep my on til they develope slop and switch to the RPM's that I have ready to install...
Here's a tip..
Before you install the ball cups drill a whole on top..3/32" or 2mm
This way you will have access to the 2mm hex on the ball stud making it easier to remove and adjust the camber links without having to remove the ball cups all together.... this will prevent the ball cups from stretching and deforming after repeated removal.
Thanks for the tip Zombies!
also, would like to add, you can screw them in the camber links as you would find in a Evo III SE.
would the holes in the graphite wear over time when your losening and tightening screws?
racer is offline   Reply With Quote
Old 02-11-2004, 04:23 PM   #1401
rc-zombies's Avatar
yes...eventually over time the whole will start to loosen.. just put some CA in there and it will be tight again...
Old 02-11-2004, 05:40 PM   #1402
pucho's Avatar
Send a message via AIM to pucho
Thanks,
No it was an AE coper spring. If you go back a few pages you will find a post with Haras cleveland set up and he used congo purple and blues (the blues are had to find but you can use the AE coper)
I already have the X-ray springs sets they have a good range and they seem to fit well on the HPI shock so I will tune with those.
Luis
pucho is offline   Reply With Quote
Old 02-12-2004, 01:34 AM   #1403
Hello,
An Urgent question to all pro4 owners.
Im currently doing part 6 which concerns bag B. It refers to part 73081 but this part is not listed in the front part of the instruction booklet. What dag is this part in? Is it in the Kit? Is it plastic or silver or purple
Please thanks for your help!
Mossie is offline   Reply With Quote
Old 02-12-2004, 01:54 AM   #1404
Vegetto's Avatar
Mossie,
Look in the back of your instruction manual and look up 73081 in the part list and you find its called a Steering Plate (woven graphite) hope this helps.
Vegetto is offline   Reply With Quote
Old 02-12-2004, 02:14 AM   #1405
Was the piece located in the B Bag or in a seperate bag? I think I may be missing the piece.
Old 02-12-2004, 03:39 AM   #1406
rc_square24's Avatar
Default steering plate
the steering plate is in the same bag as the 2 shock towers are, which is in the chassis plate/sticker bag.
rc_square24 is offline   Reply With Quote
Old 02-12-2004, 05:01 AM   #1407
snoopy's Avatar
Thanks.
I agree with RC-Zombies, the stock springs would be great for stock, probably a little soft for mod when the traction is good.
snoopy is offline   Reply With Quote
Old 02-12-2004, 05:10 AM   #1408
oops
Old 02-12-2004, 05:34 AM   #1409
snoopy's Avatar
Mossie,
I think you should slow down and go through the instructions some more. sounds like your in too much of a hurry to get it built.
Hurry......build wrong and goes like crap.
Slow.......build right and goes awesome.
Old 02-12-2004, 08:49 AM   #1410
rc-zombies's Avatar
Originally posted by snoopy
Mossie,
Take your time and you'll have the best handling car you've ever driven out of the box.....
