Like Tree5Likes
Old 02-27-2006, 04:20 PM   #13996
kewdawg's Avatar
That's HORRIBLE! Wonder what happened? Check out all the RUST! If, the screws are rusted, then so's the bearings and hinge pins. Ouch! It's not even worth the trouble.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 02-27-2006, 05:44 PM   #13997
dstyles's Avatar
Originally Posted by LORD SHADO
i bid on the ugly car . wow what a rebuild job.
good luck with that homie
dstyles is offline   Reply With Quote
Old 02-27-2006, 09:39 PM   #13998
ill use navy jelly
LORD SHADO is offline   Reply With Quote
Old 02-27-2006, 09:44 PM   #13999
ugly car info:Personal use. Got wrecked 1st in Kenner Louisiana during a drag. And then again During hurricane Katrina. 100% Not stolen. You can go check on DoriRC Forum under iGuy which is me the original owner.
im not going to rebuild its going on display at my local track , i fix it so it can run the way it is . hahahahah. may it rust in pease.
Old 02-28-2006, 08:51 AM   #14000
KillWency's Avatar
Thats no way to treat a baby!
KillWency is offline   Reply With Quote
Old 03-01-2006, 10:45 AM   #14001
Default hpi parts
http://stores.ebay.com/WalawalaStore...QQftidZ2QQtZkm
good stuff pro 4 bearings 10 bucks with shipping
jest got the bearing in from china 15days shipping.to maryland u.s.a.
Old 03-02-2006, 11:04 AM   #14002
nordheim's Avatar
Hi guys!
I sold my Cyclone and Pro 4 but had a couple of things on order before I did so. Anyone interested in the following new in package:
1 31t 64p Robinson Racing superlite pinion gear $4.00 shipped
1 32t 64p Robinson Racing superlite pinion gear $4.00 shipped
1 106t 64p Hpi Purple Spur gear $3.00 shipped
All 3 for $10.00 shipped. PM me if interested.
SEATTLEINDOORRACEWAY.COM - VALLEYVIEWRC.COM
nordheim is offline   Reply With Quote
Old 03-02-2006, 08:01 PM   #14003
nordheim's Avatar
Originally Posted by nordheim
Hi guys!
SOLD!!!!!!!!!!!!!!!!!
Old 03-04-2006, 08:06 PM   #14004
raptor 700's Avatar
How can I make the steering smoother on my car? It is very rough. Thanks
raptor 700 is offline   Reply With Quote
Old 03-05-2006, 08:47 PM   #14005
CHRIS CHAVEZ's Avatar
Hello,
If anybodys interested I just put my Pro 4 on Ebay.
Its got the Hara upgraded parts and many many extras including a FRANKS
BODY, two motors, two batteries, many parts,etc. If you want a pic and
details on all the goodies check it out on Ebay. (Search hpi pro 4)
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 03-05-2006, 10:27 PM   #14006
cclifton's Avatar
Send a message via MSN to cclifton
Default Pro 4 Question
I just picked up a used pro 4 and I was told that you can use the diff gears from a tc3/tc4 in the car. I noticed that the gears in the front oneway are almost gone. Is it true that you can use these gears in the Pro 4.
Also does anyone have some good starting points for setup on a tight carpet track with foam tires?
Chris
The Fleet:Xray:XT2 - Associated B6
For Sale :Tekno EB48SL, Kyosho RT6, RB6.6, Xray XB2 CE 2016 w/XB2 DE conversion
Poorboy Raceway and Hobbies
Grants Pass, OR
cclifton is offline   Reply With Quote
Old 03-05-2006, 11:01 PM   #14007
Registered User
You can use them, but I've found as long as your not a total noob at driving you really don't need to bother with them. The AE gears will break in a hard hit as well .. they are only slightly more durable. The v1.1 gears are pretty decent.
A good foam setup is the Thad Garner setup on HPI's site. I found it to be pretty decent, I run my front blocks level though without the front dive and it is very stable and easy to drive with a ton of steering. [Link]
Hope that helps.
Desolas is offline   Reply With Quote
Old 03-05-2006, 11:34 PM   #14008
cclifton's Avatar
Thanks for your help.
Chris
Grants Pass, OR
Old 03-06-2006, 04:27 AM   #14009
BrainTeased's Avatar
Hi i was wondering what mods need to be done to fit the AE gears on? i would have to put on the small input shaft AE gear on as well right? and that would change my internal ratio to tc3/tc4 which is 2.5 yea?
kindest regards
James
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 03-06-2006, 05:15 AM   #14010
AngryAsian's Avatar
Hey mate...
i know this doesn't answer your quuestion, but i've found the updated HPi gears to be very good. I origianlly ran the car with V1 gears and killed one on the one-way quickly.. poor shimming(it liked being tight...)
The new gears are tough enough that a couple of days running at TFTR without breakages. Including newb treatment (Friend...) with a GTB 5.5R onboard.. (Enough to break cvd's and pop hub carriers... the diff gears were beautiful)
Unless you have a bunch of associated gears lying around, you shouldn't need the AE gears...
compare the pics of the old gears with the dished edge to the new ones. They're pretty solid all the way through...
hope that kinda helps.. LoL..
AngryAsian is offline   Reply With Quote
