Like Tree6Likes
Old 02-14-2006, 09:39 PM   #13921
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
its second hand
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 02-15-2006, 07:48 AM   #13922
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Does anyone know if I can get the Hara Motor Mount thru Hpi?? and if so, what is the part#.
Thanks!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 02-15-2006, 08:08 AM   #13923
Yeah,
Here it is: #75170 HEAT SINK MOTOR MOUNT $40
http://hpiracing.com/index2.htm
Greg
I'm not as good as I could be, but I am a much improved version of what I once was.
Greg45231 is offline   Reply With Quote
Old 02-15-2006, 08:12 AM   #13924
dstyles's Avatar
but they're out
dstyles is offline   Reply With Quote
Old 02-15-2006, 09:04 AM   #13925
Stormer Hobbies has the stock one.
HPI75107 at the bottom of the page
Here is the link: http://www.stormerhobbies.com/cgi-bi...e=&man=&page=1
He is out of the Hara edition ones tho.
Greg
Old 02-16-2006, 05:02 AM   #13926
Default batterys
help help how do you solder your battery packs. or is there a web site on this topic
LORD SHADO is offline   Reply With Quote
Old 02-16-2006, 05:04 AM   #13927
Default wheel balance
do you guys balance you wheels . i all ways balance my wheels
Old 02-16-2006, 09:39 AM   #13928
Kwikvdub's Avatar
Greg
Thanks all who checked!
Alex Valdes
Old 02-17-2006, 02:22 AM   #13929
Default batterys
Soldering to Ni-Cds is not a good idea. Try to use the welded tabs and solder to those if at all possible. Soldering to the positive button will have a very high probability of destroying the nylon seal. You just can't get the button hot enough to get a good solder joint without compromising the integrity of the nylon seal ring. This ring is under compression and raising its temperature will allow it to relax and the sealing properties are history.
If you can hold a penny between two fingers long enough to get a good solder joint with #18 stranded wire or braid, then go ahead and solder to your cells, otherwise get cells with solder tabs. Remember, nylon is a good insulator, electrical and thermal. There is no thermal path for the soldering heat to dissipate when heat is applied to the cover button of a cell.
Nylon characteristics:
Nylon has its glass transition at 460°F - 500°F . The maximum use temperature of nylon 6-6 parts is about 300°F. (Note that this is considerably below the glass transition temperature.)
Soldering temperatures are in the 450°F to 650°F range.
I realize this flies in the face of all the electric flight “experts” that assemble their own packs but it is never the less fact.
You have never seen a pack assembled by a cell manufacturer or any other pack manufacturer (outside of the hobby market) where connections are soldered directly to a cell. There is a reason.
http://www.rcbatteryclinic.com/
Old 02-17-2006, 09:54 AM   #13930
dstyles's Avatar
i don't think most people use Ni-Cd's
Old 02-17-2006, 10:39 AM   #13931
Default batterys
this includes all type of rechargeble batterys were can i get tips on battrey pack making.
Old 02-17-2006, 10:59 AM   #13932
karlo511's Avatar
looks like you already did
karlo511 is offline   Reply With Quote
Old 02-17-2006, 01:35 PM   #13933
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
heres how i make packs, never had any problems:
take cells, put individual shrink wrap on them.
take cells and lightly sand (dremel w/ sanding drum) the end of each cell (both ends) where you plan to solder too, nothing agressive or anything.
now put all ur cells in your jig.
now tin all of your battery bars.
now use a HUGE soldering iron to solder ea bar on. try to be quick.
now glue your pack together.
in the past i didnt sand the ends of cells. the reason i do now is that when i didnt sand the cells i could take pliers and pull the battery bar off, without a ton of force, and usually no solder would be stuck to the cell, it would all be on the battery bar. now that i sand its as if they are welded on, no pulling them off with pliers
also a large iron helps to heat the bar and the surface of the battery to soldering temperature quicker, and SEEEMS like it keeps the cell overall cooler. idk.
as for the soldering itself, if you pretin the bar you should have enuf solder between the bar and the cell, so you just need to add solder around the permiter usually. also you dont need solder on top of the cell, just under it, and along its edges where it contacts the cell.
idk if that helps, but thats how i does it
floodo1 is offline   Reply With Quote
Old 02-17-2006, 02:12 PM   #13934
thanks alot i didnt sand the battery ends.
bars pop of like you said.
Old 02-17-2006, 10:54 PM   #13935
AngryAsian's Avatar
Has anyone actually has success with soldering AROUND the bars instead of on the bars? Apparently the solder itself is a poor condustor, so the idea is to get the full face of the bar contacting the cell, with a rim of soldering around the edge to hold it on.
I don't think i've ever been able to do that, unless i've used an obscene amount of solder! I don't want to go blocking the vents either!
Tips?
AngryAsian is offline   Reply With Quote
