Old 02-10-2006, 10:11 AM   #13876
karlo511's Avatar
Originally Posted by LORD SHADO
hara edition servo mounts are too high. what do you guys think.
time to pull out the dremmel.
mine fit, no problem.
karlo511 is offline   Reply With Quote
Old 02-10-2006, 03:17 PM   #13877
AngryAsian's Avatar
yeah make sure you've got them correctly aligned. They should result in the servo basically touching the CF deck. Make sure that you've got the right orientation. Is the turnbuckle contacting the upper deck atm? Is the linkage on a slight rear-ward angle?...
AngryAsian is offline   Reply With Quote
Old 02-10-2006, 11:30 PM   #13878
MikeR's Avatar
Trader Rating: 14 (100%+)
Sup Karlo511, Got the Hara Ed.? Nice! Maybe I'll see you at La Mirada. You can be my emergency parts support
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-11-2006, 01:49 AM   #13879
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Maybe you installed it the wrong way. Must be laydown.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 02-11-2006, 03:21 AM   #13880
Angry DA
DA you guy are frackin right ,it must be those stupid pill i been poppen. it been five year with out electric thanks guys.
LORD SHADO is offline   Reply With Quote
Old 02-11-2006, 04:22 AM   #13881
AngryAsian's Avatar
Don't worry about it...
i er....
only found out after another racer had a brief glance at my car. He was like..
"Oh... does raising the steering servo give you better steering? "
I was like.. "huh?! Raising it?.. i just assumed it was like that."
You should have seen the grin on his face...
So.. not a biggie. (Incidentally, it still works like that, just watch the clearance to the upper deck. But it;'s better to mount it correctly to begin with! LoL)
Old 02-11-2006, 11:17 AM   #13882
Red face
im glad i didnt get to the track yet da da. thell think im a newby.
Old 02-11-2006, 12:47 PM   #13883
karlo511's Avatar
Ha!
no problem mike.
see ya' around.
Old 02-11-2006, 03:02 PM   #13884
anybody have a good carpet setup
I am running pink/orange in the front and dbl pink in the rear.
Thank you
indix1 is offline   Reply With Quote
Old 02-11-2006, 05:38 PM   #13885
Send a message via Yahoo to nomaak
anybody know how to stop this weird "clicking" sound my front diff makes under braking?
nomaak is offline   Reply With Quote
Old 02-11-2006, 09:47 PM   #13886
Trader Rating: 38 (100%+)
Yep! Dont brake
One of mine does the same thing occassionally but if I run the car not under load it goes away. Not sure.
or8ital is offline   Reply With Quote
Old 02-11-2006, 09:54 PM   #13887
Trader Rating: 193 (99%+)
Thank you
I have a great set up on carpet for the Pro 4. Works great at WOH.
Here is my set up.
Front
Shocks 3 piston Losi 45wt oil
AE yellow springs or Purple (try them both to see what you like)
Shocks mounted outer on arm. (Inboard will make the car turn in quick)
Upper 3rd hole out
Camber link outer hole with .75 shim
6 Degree caster blocks
1.0 for front arm mount (0 degree for not as quick turn in)
1mm roll center shims all around
rear most hole on knuckle
steering ackerman is stock
BSR Double Pink/ Orange
Rear
Shocke 2 piston AE 35wt oil
AE copper spring
Upper mount 3rd hole out
Middle hole bottom
Hub spacing stock
ball stud in inner hole on hub
inboard link set to inner hole 2mm spacer
2 degree toe
BSR Double pink/ purple
Thin purple hex hubs with thin and thick spacers
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-11-2006, 10:49 PM   #13888
sounds like your gear mesh is to loose and your ring gear is skipping on the pinion try shimming tighter that is what it took on mine with it shimmed right I can use 100% brakes with no clicking
no1uno is offline   Reply With Quote
Old 02-12-2006, 04:01 AM   #13889
Geetoo's Avatar
That sound could be your 1way gear stripped out. It often happens once you have used it a couple of times. Better change it and check shimming.
www.hpiracing.com
www.nosram.com
Old 02-12-2006, 06:19 AM   #13890
I think I am running 1 silver and 1 copper shim on the ring gear side. And 1 silver on the other side.
Check your pinion gear(diff) for rounded teeth. It seems once it starts to skip it will continue.
www.donatelife.net
SEO by vBSEO 3.5.0
