Like Tree5Likes
Old 01-31-2006, 09:03 PM   #13816
dstyles's Avatar
Originally Posted by iblumberg
Has anyone tried the HPI bearing adapters that let you switch to 5x8x2.5 bearings for the axles (i.e., the bearings go in the steering blocks (front) and hubs (rear)). I just got a set and am about to try them, but wanted to hear if there were any nasty surprises awaiting me.
Ira
i've seen those too, but don't know who actually runs them.
does anyone use them?
dstyles is offline   Reply With Quote
Old 01-31-2006, 09:43 PM   #13817
MikeR's Avatar
Trader Rating: 14 (100%+)
What do they do? Just provide a little lighter bearing? My lighter 415MS bearings are also more fragile
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-01-2006, 12:17 AM   #13818
The adapters allow you to run a 5x8x2.5 mm bearing instead of the larger 5x10x4 mm bearing. The adapters are sleeves that take up the extra space. HPI says the smaller bearings are lighter and offer less rolling resistance.
I'll probably try them out this weekend. However, I'm not throwing away my original bearings just in case.
Ira
iblumberg is offline   Reply With Quote
Old 02-01-2006, 02:56 AM   #13819
AngryAsian's Avatar
Does anyone know how to reduce centre shaft wobble?
I just put another new one in, don't want it to turn ugly again. Actually, i looked at the pins and they were even twisted out of alignment! Is this normal? LOL...
(I'm using the stock Alu one...)
AngryAsian is offline   Reply With Quote
Old 02-01-2006, 08:01 AM   #13820
rc-zombies's Avatar
Ira
the smaller bearing are very fragile...doesn't take much to break them..
stay with the original bearings..
Old 02-01-2006, 09:59 AM   #13821
Since I have already invested in the parts and since my front bearings were squeeking, I think I'll try the new smaller bearings. However, if as you say they are much more fragile, I'll be replacing them with a new set of full sized bearings shortly (unless my driving suddenly improves dramatically) :-(
Ira
Old 02-01-2006, 10:03 AM   #13822
My original driveshaft was also showing some wobble at higher speeds (with just a stock motor). It did not show any visible signs of wear however. Nonetheless, I have crashed a few times at reasonably high speeds, so this may have deformed the shaft a bit. I recently replaced it with an HPI graphite shaft (purchased in Japan since HPI won't sell them in the US). I have no idea how long it will last, but it is certainly running straight and true for now.
Ira
Old 02-01-2006, 10:09 AM   #13823
Default HPI's non-US bling
Does anyone know why HPI sells lots more bling and functional hop ups outside the US than in the US?
Take a look at the HPI website in Japan and you will see that HPI has graphite drive shafts, alu spring retainers for the shocks, alu shaft drive cups, alu ball ends, graphite top bumper plates, alu front and rear hubs, alu antenna holders, etc. Even in Eurpoe, most of the above parts are available.
Some of the above stuff is just bling, but some really does improve performance and/or reliability. Why would HPI not sell it in the US?
Any thoughts?
Ira
Old 02-01-2006, 10:49 AM   #13824
MikeR's Avatar
Ira
Ok, thanks for the answer.
Maybe the bling parts you mention are just new and haven't had time to hit the US shores. It's always been that way with Tamiya as well- usually a 2 month progression
Old 02-01-2006, 12:17 PM   #13825
AngryAsian's Avatar
graphite shaft eh...
Incidentally, can anyone tell me whether its because my drive cups are out of line, or does the shaft just naturally do this? I just swtiched to running mod recently and i killed a shaft promptly. Might be a sad coincidence but does this just happen?
The previous shaft did "sing" at part throttle and on the stand at least practically roared at you on full throttle. I think it has a nasty resonance to it. The new one is very much better but still deforms on the car stand(no load) at full throttle.
Old 02-01-2006, 03:46 PM   #13826
raptor 700's Avatar
I have pro4 and want to know what change can I do to make it cary more speed through the corner? I currenting run a spool, and the track is fairly techianly and slow. Another thing my inside tires jwrecks from left to right in a full throttle swepper? Thanks for the info.
raptor 700 is offline   Reply With Quote
Old 02-01-2006, 11:56 PM   #13827
Nicadrauspro4's Avatar
The HPI graphite shaft can only handle motors with 12t limit and above. Once you go below the limit, your graphite shaft will break as it can't handle the very high RPM of modified motors. On the other hand, the HPI graphite shaft performs well with 19T and 23T, very smooothly. If you want a tougher graphite shaft, check the thread by ewippler who fabricates graphite shafts for all motors and car makes.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 02-02-2006, 12:00 AM   #13828
Try using a one-way diff on your car. Then check the difference. Though I have never tried using a spool, I'm using a one-way and my pro4 can make high speed turns in some corners and chicanes with no problems.
Old 02-02-2006, 02:55 AM   #13829
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Or maybe you can try this. If you run on smaller tracks with tight turns, the usual case is you must use a lower degree C-hub. Instead of 4deg, try 2deg. This way you have more off-power turn in on corners, this would help your car move faster all around the track.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 02-02-2006, 04:05 PM   #13830
raptor 700's Avatar
I already tried the one-way and didn't like it one bit. It would oversteer and understeer. It was to hard to drive.
