Old 01-12-2006, 10:08 AM   #13681
fjm9898's Avatar
if your running foam tires, the copper is the way to go. i use the pruple in the front. also if you have a sway bar in the rear take that off, that will freee up the car.
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 01-13-2006, 05:50 AM   #13682
Hey guys im about to buy a pro4 just want to ask a few questions. Is there any parts that are prone to breakage? i am in a deal with a guy atm who is selling a pro4 with the hop up options of Steel UJ in front, Alum centre outdrive, carbon center shaft, 1 pc alum spur gear holder, addtional used 2mm chassis, roll bars. what would u pay for it?
cheers,
Pat
*sil80* is offline   Reply With Quote
Old 01-13-2006, 06:00 AM   #13683
AngryAsian's Avatar
Hey Pat.... nice to see you're joining the dark side....
I paid around 300ish for mine. But mine came with enough spares for a second car plus a little...
Spares to buy.... CVD's and bones..
The pro4 cvd will bend if you're running on a track. Either get some IRS tc4 plastic's on the cheap or upgrade to Ti world ed. ones. You're having the steel UJ's will be fine.
bevel gears (for the diff)
Again, these suffer in crashes... or improper shimming. A MUST buy..
suspension pins...
Front sus. arms
and if you end up getting the brushless... then eventually you'll need diff outdrives.
But... summary.
BEVEL GEARS,
CVD BONES
FRONT SSUPENSION ARMS
let me know when you get the car..
I can sweeten the deal for you by taking the alu centre drive cups and CF shaft off ya...I have another shaft on order but you know me....
AngryAsian is offline   Reply With Quote
Old 01-13-2006, 06:17 AM   #13684
Thanks angry lol the dark side. shaft seems better for me because its going to be used in the carpark across the road alot and i kept getting stones cought in the diffs and stuff of the 415. im getting it for 320 deliverd to my door wasnt sure if that was over priced or not didnt seem 2 bad. Im not sure about brushless atm im running pretty low on cash atm and not working as much as i need to be lol.
Old 01-13-2006, 06:23 AM   #13685
AngryAsian's Avatar
Yep.. same reason i got the pro4.. shaftie AND enclosed drivetrain..
Let me know about the centre shaft and drive cups. If they're in good nick, i'll seriosuly sweeten that deal for you. Been looking for those items for a while. You can have my old shaft and drive cups, and the new shaft when it arrives...
how soon are you getting the pro4?
Old 01-13-2006, 06:27 AM   #13686
ill have a think about it angry as i really dont need all those goodies. Umm not sure the 415 will probably be gone on monday or tuesday or as soon as the money clears then probably 2 or 3 days to get here so hoping to have it friday at the latest. what is the drive cups exactly?
Old 01-13-2006, 06:38 AM   #13687
AngryAsian's Avatar
the centre shaft is coupled like a CVD via some drive cups.
So.. going from tranny out.
Diff outdrives(Drive cup)
CVD dog bone
CVD axle
Wheel hex
Wheel..
same deal on the centre shaft.
From front of the car to back...
Front Diff - Drive cup - Shaft - Drivecup - Rear Diff
Like i said, i can do a swap ... yours for mine(providing they're in good nick) and i'll chuck some bling in ther too. My alu centre shaft is on backorder in HK.
The current ones i had have a little slop and the centre shaft is ugly. Battle scarred but fine. I've been wanted to get the alu centre drive cups(more accurate) and another shaft for a while...
Old 01-13-2006, 06:47 AM   #13688
dunno mate are they really that hard to find around here?
Old 01-13-2006, 07:40 AM   #13689
AngryAsian's Avatar
Lol... not really.
Not going to be able to get them locally. Easy to order from OS, but i like buying local. Might buzz MRC and see what they can do for me if you're not interested.
Oh.. you going to TFTR on sunday or monday?
I'll be there on monday unless it's bad weather, and most likely on sunday too.
Old 01-13-2006, 09:09 AM   #13690
dstyles's Avatar
anyone using the square drive shaft cups experience binding?
dstyles is offline   Reply With Quote
Old 01-13-2006, 07:15 PM   #13691
ngo8's Avatar
Send a message via ICQ to ngo8
if anyone is looking for BMI carpet chassis conversion let me know i have one for sale .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-13-2006, 07:43 PM   #13692
raptor 700's Avatar
what is the top deck mod?
raptor 700 is offline   Reply With Quote
Old 01-13-2006, 10:42 PM   #13693
jimlazaro's Avatar
Hello everybody!I need help,here's what I have on my car:
novak brushless 5800
100 spur gear
31 pinion gear
spool on the front
white spring front and rear
sway bar front and rear 1.6
Ok here's my experience on this car,when I accelarate the car won't go staright,I fixed already from my radio to make it straight but still nothing happen, maybe when I changed my spur gear from 48 pitch to 64? I checked and everything are all even,ride height,spring,etc.Need help to you guys......
jimlazaro is offline   Reply With Quote
Old 01-13-2006, 10:56 PM   #13694
ngo8's Avatar
take 2 orings and 2 countersung washers turn them upside down put in the orings in the countersung part and screw them down where your 2 steering posts are on the top deck but not to tight
Old 01-13-2006, 10:58 PM   #13695
easy e's Avatar
Trader Rating: 28 (100%+)
I know this isn't related but would anyone know a place that has pro 2 parts in stock ?
easy e is offline   Reply With Quote
