Like Tree5Likes
Old 12-24-2005, 01:05 PM   #13636
Nicadrauspro4's Avatar
Originally Posted by Essnowyt
Nicadrauspro4 - Its all personal preference. I still run 48pitch becuase I dont want to spend $30+ dollers on a set of 64pitch gears. I have a full set of 48 from ages ago. Others that run big mod motors use 48 as to not destroy spurgears.
As for smoothness, a 48 pitch Kimbro Spur and a Robbinson Racing Alumium Pinions are just fine. Stay away from the heavy steal pinions.
Snowy.
Oh, maybe I'll try the 48 pitch when I run with mod motors. Thanks!
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 12-24-2005, 01:37 PM   #13637
fjm9898's Avatar
anyone know if HPI sells a diff rebuild kit?
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 12-24-2005, 01:45 PM   #13638
Registered User
I don't think there is a one-shot rebuild kit that has everything other than a new diff kit. They have a parts bag with the diff rings, and balls .. then another bag with the thrust assembly (or use the AE one.)
You can buy the bearing that goes in between the out drives as well. Since individual components tend to fail its cheaper to by it part by part.
If your just looking for that small washer that goes under the thrust spring, your SOL because for some reason it has been unavailable since day one from HPI. It is thinner than the AE one, and I tried using a AE one instead and had very odd issues with keeping the diff together. You also can't just use a thrust washer there either because it's too thick. I have a diff built with just a washer I found that fit well enough, and the diff works but for some reason it makes it chatter.
I've searched HPI's site, and tried getting ahold of them and all I've gotten was "it's on backorder" as a response.
Desolas is offline   Reply With Quote
Old 12-24-2005, 10:55 PM   #13639
Red face set ups
what set up should i use for tar it and has lots of grip im running foams 35 r/40f -19t and stock class 27t and red springs front tc3 /rear silver stock springs also its hot were i live thanks
serpentrush is offline   Reply With Quote
Old 12-26-2005, 04:43 AM   #13640
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Nicadraus: I suggest you use 64pitch, our track is as smooth as ever no pebbles or rocks that can ruin your spur. On the other hand, 64 pitch plays a vital role on you FDR, by selecting ratio in small inrements compared to 48P.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 12-26-2005, 12:28 PM   #13641
Ok Garet. I'll take your advice. Thanks!
Old 12-26-2005, 05:07 PM   #13642
Hi, only reason I'm looking at swapping to 48pitch is because of outdoor racing.Recently, I ran our state titles and in practise, almost destroyed the 64pitch spur gear.no one else ran 64p and none of the hobby shops had any in stock. I ended up removing the damaged spur and turning it around,ran the 2 day event with it and finished 2nd in the B Final.Although the competition wasn't really hot, I am very happy with the strength and durability of the Pro 4 !!!
jim beam is offline   Reply With Quote
Old 12-27-2005, 03:28 AM   #13643
jland's Avatar
Trader Rating: 74 (100%+)
Default Spool?
Quick? With the HPI spool that comes with the Hara, I have noticed there is a chattering sound and alot of vibration in the front when the car is benched and you turn it to the left or right. Has any-one else noticed this? Anyway to make it better. Do you use greese on the outdrives of the spool?
Thanks for the help..
jland is offline   Reply With Quote
Old 12-27-2005, 08:34 AM   #13644
rc-zombies's Avatar
that is normal when running with a spool.. this happens with other cars as well..not just the pro4.
Old 12-27-2005, 01:03 PM   #13645
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
the hpi spool COMES with grease. use it
in fact use it on all your drive pins (cvd's and center shaft)
floodo1 is offline   Reply With Quote
Old 12-27-2005, 04:59 PM   #13646
in the hara editon there was a tube labeled heavyduty grease #z164 it looks like dark green in color i did not use it in the kit but i what to know if i can use it on the thrust bearings because i ran out of that black grease they supplied?
bosfan is offline   Reply With Quote
Old 12-27-2005, 05:33 PM   #13647
I never found any instructions for what that tube of grease was for. Anyone know?
Ira
iblumberg is offline   Reply With Quote
Old 12-27-2005, 07:24 PM   #13648
pucho's Avatar
Send a message via AIM to pucho
A buddy of mine and I where trying to find out what the hell HPI used for the trust grease, we narowed it down to anti-zease compound, you can buy a whole tube for a few dollars at any local auto parts store.
pucho is offline   Reply With Quote
Old 12-27-2005, 10:22 PM   #13649
How can I get more corner speed without having a unstable rear?
I hope that does not sound to odd
kyracer is offline   Reply With Quote
Old 12-27-2005, 11:44 PM   #13650
Thanks for your help Dodgeguy
