Old 02-08-2004, 12:31 PM   #1351
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by rc-zombies
Why order from Towre for $400+++ when you can pre-order one from speedtech for $290
I think he's talking about the hacker system.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-08-2004, 03:53 PM   #1352
tcdrvr's Avatar
Default Pro 4 at Snowbrids II
Well I wasn't able to use the car much after I broke it, although I did try to remount the ballstuds on the upper deck in front of the shock tower, it didn't handle the same. I then tried to use my Yokomo (which I had converted to the CGM) but after two laps and a light tap on the boards it broke too. So I used the HPI again however I was too afraid of breaking the car since I needed to actually finish one qualifier. The worst part about the whole weekend was that the Pro 4 was awesome at the club race, the first round I was running in third and gaining on second when my batteries split apart then in the second round I put a lap on the entire field. Oh well next year I'll be able to get parts on a regular basis so it'll be all good.
tcdrvr is offline   Reply With Quote
Old 02-09-2004, 02:13 AM   #1353
snoopy's Avatar
Originally posted by Vegetto
Hey guys,
I get my Pro 4 in two days, does anyone know were I can get a Hacker Brushless 6 turn and MASTER CAR COMPETITION BRUSHLESS CONTROLLER w/BEC???
Any info would be great.
Try Perth R/C Models & Hobbies. They are the australian agent for Hacker.
snoopy is offline   Reply With Quote
Old 02-09-2004, 03:46 AM   #1354
Vegetto's Avatar
Thanks for the info guys I will send some emails away..
Vegetto is offline   Reply With Quote
Old 02-09-2004, 04:40 AM   #1355
JohnA's Avatar
Default Re: Pro 4 warning
Originally posted by tcdrvr
I don't know if any of you have encountered this problem but I was disassembling my Pro 4 to rebuild my diff and during the disassembly the outer piece that attaches to the diff case snapped in half in my hand. Just a warning to all other Pro 4 owners be careful when disassembling this car..... especially before qualifying for a big race.... like snowbirds
Do you mean the brace that the upper arm link attaches to? If you do there was a guy at out local club took a light T-bone and broke hiss in his first race, hop we haven't found a weak spot! MAybe someone will release some carbon fibre ones???
JohnA is offline   Reply With Quote
Old 02-09-2004, 04:52 AM   #1356
snoopy's Avatar
Default Re: Re: Pro 4 warning
Originally posted by racer
that is true. i almost did the same. think it would be better much stiffer if we didn't cut the small bar that goes across the two ends.
All the insrtuctions of the pro4 show this little bar cut....However if you look at the latest pics of Hara's car he has left this bar in place.
I have done the same on mine as it seems to add that little bit of extra strength.
Old 02-09-2004, 10:27 AM   #1357
Pro4 option : Titanium input shaft
Kingcrab is offline   Reply With Quote
Old 02-09-2004, 10:32 AM   #1358
rc-zombies's Avatar
Those are nice...really improves accelleration. half the weight of the stock steal parts.
I've got them in my car already...
Old 02-09-2004, 10:35 AM   #1359
Ceramic Ball bearing set from Excel
Old 02-09-2004, 10:36 AM   #1360
rc-zombies's Avatar
Nice...
Old 02-09-2004, 10:42 AM   #1361
Aluminium Damper support
Old 02-09-2004, 10:55 AM   #1362
My charging unit
Old 02-09-2004, 11:15 AM   #1363
Send a message via ICQ to lawndoggie Send a message via Yahoo to lawndoggie
16000Yen for bearings!!!!!!!!!!!!!??
lawndoggie is offline   Reply With Quote
Old 02-09-2004, 03:46 PM   #1364
racer's Avatar
i was told that titanium input shafts will wear over time, is that true?
racer is offline   Reply With Quote
Old 02-09-2004, 03:49 PM   #1365
rc-zombies's Avatar
If it does...it will be very minimal since the shafts are bearing supported... I don't see it being a problem. the wear is less compared to the Tobee Craft version which is made of Aluminum.
