Hpi Pro 4
IRS has thick TC4 dogboes with pin cushions installed. With 4 holes on the cup side. A little pricy at 27.99 for 2. But are much thicker
Through an unfortunate series of events, I have determined that Associated TC3/4 bevel gears do not fit the Pro 4 without major cutting as the hole in the large gear is too small to fit on the spool shaft and the small gear is a bit too small to fit on the ball cup drive shaft.
Just one more part for which I will need to carry spares.
Ira
Ira
Tc 3/4 ring gears fit just fine they have three different ones one for the diff
one for the oneway and one for the spool you do not need to use the small gear at all use the stock gear
Just a question here. Why would you use the TC 3/4 gears? Would this be a track issue like. They only have TC4 gears?
Also, I had heard that the TC4 gears were stronger. Regardless, there were no HPI gears at the track.
Ira
Much stronger gears work much better with spool or oneway
Thanks,
Ira
thanks floodo1. good reply! (even if it sounded just like my previous post. JK. )
dodgeboy...xxxkat....mods worked! well on cold asphalt any way. . turn-in is quick and dead on! almost too quick! i ended up using 0F block up front and 2.5F/R block in the back. the front is VERY aggressive! can't wait to try it on carpet! this should be great! for initial tests i'm gonna try "wraps" plaid front/dbl pink rears. and i'm gonna take this insane FLATLINER out and toss in a Hellfire! should be intrestin-k in stock...but i DARE not try it in mod yet. just don't wanna break out the dustbuster yet.....i need all my peices together.
floodo1 has a great set up for carpet..
i wonder if he has a 19 turn or stock set-up? afet reading thru some past post's i'm gonna try the car out with:
FRONT: #3 pistons, AE60 wt, white springs, 5mm droop, 1.6 sway bar 0degree front sus mount. 1.5mm under front mount...1.75mm under rear sus mount...3mmm of rollcentre...camber link on outer position 0 degree toe. ride ht..4mmm
REAR: (change #3 to #2 piston) AE40 wt, purple springs, 4 droop, no swaybar,2 degree rear sus mount, 1.5mm under front&rear sus mount, 3mm of rollcentre, shortest camber link possible.ride ht4.25 mm
MOTOR: 7x2 TRiRotor FLATWIRE(old..yes i know) in Binary can with SV2 endbell. 100/27 on 59 mm tires.
I will check the part number at the track tues night and let you know
Originally Posted by floodo1
stock rubber carpet
stock rubber carpet
may try to hit Stockton or HW over the holidays...
anyone have good/bad experience with the tobee craft drive shaft?
thanks.
thanks.
