Old 11-23-2005, 05:07 AM   #13471
Revs's Avatar
Originally Posted by PD2
OK - so is this the correct part/part number:
http://www.speedtechrc.com/store/ebp...nid=167&id=106
Thanks!
PD2
Correct mate.
Revs is offline   Reply With Quote
Old 11-23-2005, 06:16 AM   #13472
PD2
PD2's Avatar
Originally Posted by Revs
Correct mate.
Thank you! Not a bad price for a big fix!
Cheers!
PD2
PD2 is offline   Reply With Quote
Old 11-23-2005, 04:53 PM   #13473
Din Viesel's Avatar
Can anyone tell me of any other websites that sell aftermarket hop-up parts for the Pro4
I have been to Allstarhobbies and Speedtech just looking for more!
Din Viesel is offline   Reply With Quote
Old 11-23-2005, 11:27 PM   #13474
Well what are you looking for? I know that RCmart sells a lot of parts for the Pro4, the only thing is shipping kinda takes a while cause they are in Tiawan
The DOC
DR.FeelGood is offline   Reply With Quote
Old 11-24-2005, 02:26 PM   #13475
Hi there people i really need your help as i am stuck and cant have my car setup well i have tried everything as for tyres but seems that molded inserts work wel on me although 95% of the drivers at the track run foams.
I think i have a droop problem basicly i am running copper front suspensions and silver rear my ride hight is 4.5 front 5 rear as the manual says, the droop is also like the manual says but whats happening is that on tight corners the car is litterly sliding 180 degree. I was readig about doing more droop on the left than the right but could understand it also i bought the copper HPI weight where is the bes to install these right next to the motor on the right hand side or in the middle ?
Thanks for looking and helping
speed6 is offline   Reply With Quote
Old 11-24-2005, 03:14 PM   #13476
Hi speed6, i guess ur running the front 1 way ? make sure u have dialed the brake out of your radio,also you shouldn't try using brake at all with the 1 way.i just ran my car for only its second time on a bitumen track with rubber tyres and the car never thought about spinning. if it is a track that requires braking, then i suggest putting a spool up front
jim beam is offline   Reply With Quote
Old 11-24-2005, 05:27 PM   #13477
Yes i am using a front one way but i don use the brake at all, its more of a tyre grip issue maybe at some sort of time when i enter a corner aggresive one of the wheels is not touching 100% the ground resulting in wheels spin .
What droop should i run with my spring setup ?
Old 11-24-2005, 06:15 PM   #13478
If someone is looking for a nice used Hara Edition Pro 4 I have one...
jjm591@aol.com
Ginsu is offline   Reply With Quote
Old 11-24-2005, 10:45 PM   #13479
tc3 racer sc's Avatar
Default what page the piston sizes on
hi i need to know what page are the piston size thxs reggie
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 11-25-2005, 02:14 AM   #13480
Default pro 4
h i was wondring if any one could help me i was wondering if i should use a one way or a spool i m running on concreate and there is no grip and i have had a couple times where i spin out and was if i should change the front to a spool or make me shocks more lighter can any one help
thanks matt
snap_u2000 is offline   Reply With Quote
Old 11-25-2005, 03:32 AM   #13481
PD2
PD2's Avatar
If you are talking about the shock piston sizes they are on page 22 of the Pro4 manual, step #30.
Hope that helps!
PD2
Old 11-25-2005, 02:30 PM   #13482
Hi Snap,soften the suspension rite up, lower the ride height to 4.5front 4.8mm rear.I run the spool as standard so i guess i'm biased, but on a slick track i think it will work great
Old 11-25-2005, 09:26 PM   #13483
ngo8's Avatar
Send a message via ICQ to ngo8
if anyone is interested in a pro 4 i have with bmi chassis set included the car is turned into a hara and is brand new with new everything including diff outdrives gears and all any interested let me know ill send you some picts thanks.
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-26-2005, 04:29 PM   #13484
Revs's Avatar
Hi,
Use a droop of 4 on the front suspension arms, a droop of 3 on the right hand rear suspension arm and a droop of 2 on the rear left.
Old 11-27-2005, 12:45 AM   #13485
jayrodracer's Avatar
Thumbs up pro 4 parts!!!!!!!!!!
i have for sale brand new one set of "Square Purple Alum. .5 Rear Hubs for Pro4/Cyclone." One brand new set of "Square Purple Alum. Center Cup Joint (2pcs) for Pro4" and one "carbon fiber center main shaft for pro 4." "One Set Of Tobee Craft Purple Alum. Front bumper posts." Offer me a price for all or for individuals.........
jayrodracer is offline   Reply With Quote
