Like Tree5Likes
Old 11-21-2005, 03:04 PM   #13441
Scottmisfits's Avatar
I had a bunch of 48 pitch pinions so I switched over to the Kimbrough gears. I have run the 2 screws for quite a while now with no issues.
Scottmisfits is offline   Reply With Quote
Old 11-21-2005, 03:07 PM   #13442
Mitropoulos Jim's Avatar
Originally Posted by ngo8
one problem...was that the diff plates(rings) backed off so i had to CA them on the outdrives after all that finally it stoped backing off ...i hope it helps.
Hi,
A friend of mine has the same problem(415 MSX)!!!
I didn't ever faced this kind of problem when racing with my pro4.
The solution is simple,I think:
When I build my diffs I always run in them oh the track and then,I tighten till they are ok and do not slipper at my hands,not at the car!
This problem occurs when you overtighten the diff and/or don't run it in.
I hope this helps...
Jim
Mitropoulos Jim is offline   Reply With Quote
Old 11-21-2005, 08:40 PM   #13443
ngo8's Avatar
Send a message via ICQ to ngo8
Originally Posted by Mitropoulos Jim
Hi,
Jim
i run on carpet and i dont even think about it i always glue my diff rings to my outdrives
ELLAS OLE
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-21-2005, 09:55 PM   #13444
rc-zombies's Avatar
there's a guy on the boards that re-anodized aluminum parts
Here's the TC4 HD CVD bones re-colored to HPI Purple.
and it's a perfect match too
he also did my AH12 and cyclone.
Old 11-21-2005, 10:10 PM   #13445
anthony390's Avatar
Send a message via AIM to anthony390
does those tc4 HD have the pin coushins on it?
anthony390 is offline   Reply With Quote
Old 11-22-2005, 02:46 AM   #13446
Revs's Avatar
Originally Posted by PD2
Gotcha - so that is different than the Pro 4 nut and screw, right? Is it a different part number and all? Or do you have a part number on it?
Thanks!
PD2
Hi,
I found the new hpi diff bolt to be just as weak but it didnt loosen off so it does half of its job , id go for the associated bolts much stronger and dont seem to back off although i still thread lock them just incase.
Revs is offline   Reply With Quote
Old 11-22-2005, 03:13 AM   #13447
PD2
PD2's Avatar
Originally Posted by Revs
Hi,
OK - so is this the correct part/part number:
http://www.speedtechrc.com/store/ebp...nid=167&id=106
Thanks!
PD2
PD2 is offline   Reply With Quote
Old 11-22-2005, 06:09 AM   #13448
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hey Zombie,
are there fit pro 4 CVD or cyclone CVD? may i know what is the orginal cyclone kit come CVD or U-joint in US spec?
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 11-22-2005, 06:35 AM   #13449
losi_g+'s Avatar
Hi.
As you probably have guessed by the name i run a Losi. I dont wish to offend any of you guys but id like to know what the differences between the pro 4 and the cyclone are and in particular, why 3 of the top drivers (Hara, Moore and Surikarn) have switched o using the cyclone.
Thanks for your help guys.
losi_g+ is offline   Reply With Quote
Old 11-22-2005, 06:47 AM   #13450
HMMM... The company that they drive for told them to drive the new car to boost sales. Maybe.
Charles is offline   Reply With Quote
Old 11-22-2005, 07:59 AM   #13451
rc-zombies's Avatar
no pin cushions... but you can easily replace them with the pin cushion kit.
Old 11-22-2005, 08:02 AM   #13452
rc-zombies's Avatar
Originally Posted by Guo Chean
Hey Zombie,
cyclone does not come with MIP CVD's.
comes equipped with standard CV's that is found in most Japanese cars... the Tamiya TB02 42mm steel CV bones and axle fit the cyclone for better durability.
Old 11-22-2005, 08:20 AM   #13453
Nipple's Avatar
Hi Guo Chean,
saw your name on the FEMCA ISTC Drivers list.
You will be driving a PRO4?
Well I'm the only HPI/HB Drivers from Singapore that will still be driving a PRO4. All the rest have switched to Cyclone.
You have any tips for that track to share?
Nipple is offline   Reply With Quote
Old 11-22-2005, 10:10 AM   #13454
Oasis's Avatar
Trader Rating: 36 (100%+)
Originally Posted by losi_g+
Hi.
I think that a belt car works better in mod than a shaft car.For stock I like the Pro4 more,The Cyclones I have driven have more on power steering than any Pro4 I have driven,One BS thing with the Cyclone is the stock shocks leak..come on..$430+ and i need to replace shocks..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 11-22-2005, 10:15 AM   #13455
rc-zombies's Avatar
not only they leak but the adjust nut doesn't hold due to no O-ring.
replaced the cap and nut with Pro4's. the Pro4 cap provides a better seal.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
XtremeJDM
