Like Tree6Likes
Old 11-20-2005, 08:09 PM   #13426
jimlazaro's Avatar
Hello fellow racer,I need your help My diff at the back keep loosen,I put a lock nut,glue still keep loosen,what I need to do,help me
jimlazaro is offline   Reply With Quote
Old 11-20-2005, 08:19 PM   #13427
Edwin Lee's Avatar
There may be few causes for this to happen:
1. The lock nut does not lock properly - change a new one and c if it helps
2. The ball bearings and the spacers at the lock diff screw may not be assembled properly. - check again - it will be good if you replace them with the tamiya diff trust bearing. The balls are sealed and wont come lose like the Pro4's.
3. The diff is not tightened properly . - make sure the diff is tight but not too tight causing the diff to jam up.
4. The diff screw has oil or grease on it. - If the diff screw has oil, the lock nut will not lock properly.
Try these and c if they help.
Edwin Lee is offline   Reply With Quote
Old 11-21-2005, 07:53 AM   #13428
Revs's Avatar
I found the hpi diff bolts and screws to always be inconsistant. They seem to loosen or snap quite often especially when under stress. The tc4 T NUT set is a great replacement, it comes with a new nut that doesnt seem to loosen, and a screw that doesnt snap, and its a direct replacement its worth looking into if you get fed up of the hpi diff bolts.
Revs is offline   Reply With Quote
Old 11-21-2005, 07:56 AM   #13429
PD2
PD2's Avatar
Do you have a part number or link to that part for the TC4? Good info!
Thanks!
PD2
PD2 is offline   Reply With Quote
Old 11-21-2005, 08:00 AM   #13430
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
i agree with what you say last time i use to used the original diff screw i had been broke 3 screw and few nut even i putting locktide also would not effect after i had change to TC3 diff screw set i solve all the problem that i had before
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 11-21-2005, 08:03 AM   #13431
Trader Rating: 194 (99%+)
I am runnnig a Pro 4 now. It is a great car. I had a FT TC4. That was OK but it lacked corner speed.
In my main yesterday the car was running great. I was fighting for second. It was a great bumber to bumper race with the other fellow. But anyway my car seemed to act funny. It did not have the rip like before. I thought it was the battery or motor. When I got home last night I found the cars front whhels would spin one at a time. I have a diff in. So this is not right. I will take it apart tonight. This latest post about diff bolts makes me think I may have a broken bolt.
I did snap a TC4 diff screw before. So those can break also.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 11-21-2005, 08:44 AM   #13432
jimlazaro's Avatar
Hi Rev we need info that you talking about or part# too,Thanks
Old 11-21-2005, 12:04 PM   #13433
ngo8's Avatar
Send a message via ICQ to ngo8
one problem i had with my pro4 was the diff backed up especially on carpet what causes that is the thrust bearing is catching inside the outdrive beacuase it wasnt greased enough that was one problem the other was that the diff plates(rings) backed off so i had to CA them on the outdrives after all that finally it stoped backing off so you try those 2 things just remember cake on that grease on the thrust bearing i hope it helps.
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 11-21-2005, 12:09 PM   #13434
ngo8's Avatar
oh yeah another thing is get rid of those HPI nut and screw and replace them with the associated thrust bearing nut and screw its a proven fix HPI did improve this witht the HARA EDITION you can get that to
Old 11-21-2005, 12:18 PM   #13435
PD2
PD2's Avatar
Would it be these then:
http://www.speedtechrc.com/store/ebp...id=189&id=1399
PD2
Old 11-21-2005, 12:29 PM   #13436
ngo8's Avatar
Originally Posted by PD2
this is what you need
Old 11-21-2005, 12:38 PM   #13437
PD2
PD2's Avatar
Gotcha - so that is different than the Pro 4 nut and screw, right? Is it a different part number and all? Or do you have a part number on it?
Thanks!
PD2
Old 11-21-2005, 01:03 PM   #13438
PD2
PD2's Avatar
I think this is it, right?
http://www.hpiracing.com/piw4.php?part=73522
PD2
Old 11-21-2005, 01:05 PM   #13439
ngo8's Avatar
DIFFERENTIAL SCREW AND HEAVY-DUTY NUT (2mm) SET 73522
DIFFERENTIAL SCREW M2x25mm (2pcs)A162 this are the part numbers
Old 11-21-2005, 02:27 PM   #13440
Din Viesel's Avatar
has anyone tried any other spur gear brand other than the stock one that comes with the car? I picked up a 100th 64p spur from Kimbrough and found that only 2 of 4 screws lines up!
also I just recieved my bmi chassis and tried it out this weekend, I seem to have a problem with the cars ass end wanting to swap with the front when I let off on the throttle going into a turn (BOTH LEFT AND RIGHT). also when I try getting back on the throttle the car pushes like a pig. I have checked all my shocks for equal length, I checked for binding in the wheels, I checked both front and rear diffs, I checked for tweak. I don't know why it's doing this? Has anyone else had this issue? I am still trying to chase that sweet setup so I know eventually I'll get it.
Din Viesel is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mattparsey
