Old 11-14-2005, 05:51 PM   #13381
CPatrick's Avatar
Send a message via MSN to CPatrick
Default Nice Pro4
Hey Mitropoulos,
That's a very sharp and clean Pro 4! I'm sorry that I'm not in the market for another Pro 4, but I was wondering if you could tell me where you found those anodized shock mounts?
I've finally begun to race my Pro 4, and now know that I should have spent more time with a cheap basher. This thing is so damn fast and responsive that I can't begin to imagine driving it on carpet with a one-way. And it's super quiet.
In the last 3 weeks, I've broken 2 front suspension arms, 1 rear C-hub, 1 front C-hub, and managed to crack a Parma wheel. When I manage to keep the car off the walls, it's a rocket.
CPatrick is offline   Reply With Quote
Old 11-14-2005, 07:46 PM   #13382
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by CPatrick
Hey Mitropoulos,
the aluminum shock balls are an HPI part. 8 dollars per 4 pack iirc. A HUGE Improvement over the plastic balls. a MUST if you ask me. i never collapsed a plastic ball on the top screw, but i squashed ALL of my lower ones. the aluminum balls cant be crushed, but they also fit better (less slop).
moving on: hahahah i was reading about all your broken parts and im like "wow thats a lot of stuff" then i see the parma wheel and i get all ready to post "stop hitting stuff so hard!" and then you're like "i hit the wall too much!" hahahah
but yeah aluminum shock balls are one of the best upgrades, wish i had a p/n to throw down, shouldnt be hard to find tho
floodo1 is offline   Reply With Quote
Old 11-14-2005, 07:49 PM   #13383
Din Viesel's Avatar
I was looking at the Andy Moore setup for carpet and wanted to try it, but can someone tell me what the thickness is of the teflon washers he uses in his shocks? It just says 1 teflon washer or 2 teflon washers but no thickness!!
Also can someone let me know if they tried this setup and what they think! thanks
Din Viesel is offline   Reply With Quote
Old 11-15-2005, 06:04 AM   #13384
Trader Rating: 193 (99%+)
What do you guys think of the Delrin outdrives? I have a set when I got my car. I have not used them yet. Any down sides to them?
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 11-15-2005, 06:43 AM   #13385
CPatrick's Avatar
Default Thanks Floodo1
Thanks for the info floodo1. I'm on it.
Anyone remember me trying to get some Titanium CVD bones made for free? Well, I checked in to see if anything had happened with them and found them still sitting on a guy's desk. With the Holiday's approaching, and work easing up a bit, I think that I can ask one of the shop machinists to turn a couple, or show me how to make them.
Now, if I could only figure out how to make my own suspension arms and C-hubs...
Old 11-15-2005, 07:30 AM   #13386
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
The delrin makes for a super smooth diff. Combine it with some cermaci diff balls and you'll have one of the smoothist longest lasting diffs on the planet. No downside....unless you consider smooth..free flowing operation with zero wear and maintenance a downside
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
SOuthernFRIED is offline   Reply With Quote
Old 11-15-2005, 08:12 AM   #13387
floodo1's Avatar
main thing about delrin outdrives is that they are machind. therefore the tolerances will be MUCH higher. i know that i have a set of molded outdrives that are angled. that is the diff rings sit at an angle relative to the bearings, so the diff always gets tighter/looser as you rotate it! VERY annoying
Old 11-15-2005, 09:32 AM   #13388
Mitropoulos Jim's Avatar
That's why Idon't like derling outdrivesahd don't ever use them,plus they are easy to break if you have a big crush!!!
CPatrick,thanks!It's my baby...you know...
About your question,floodo1 has answered exactly in the same way Iwould...
Mitropoulos Jim is offline   Reply With Quote
Old 11-15-2005, 11:22 AM   #13389
I think Floodo was saying he wouldn't use the stock molded outdrives.
If you are saying the stock outdrives are better than the Delrin you are sadly mistaken.I can't imagine what your smoking to make that kind of comment.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
Old 11-15-2005, 01:51 PM   #13390
I have seen aderlin outdrive in two pieces,after a bad crash.So,to avoid that I don't use them and I am satisfied with the stock ones.If you aren't,it's probably your mistake,mabe you build the diff the wrong way...
Old 11-15-2005, 02:02 PM   #13391
rc-zombies's Avatar
I find the delrin outdrive more durable than the stock graphite parts.
the stock graphite parts are brittle and more prone to breaking. Delrin diff is super smooth and light...
let's not get into a battle of which is better or not..to each his own.
Old 11-15-2005, 04:54 PM   #13392
Yes I am sure I probably built the diff wrong
sorry nevermind
You stick with the stock and I'll stick with the Delrin.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
Old 11-15-2005, 05:36 PM   #13393
Company Representative
Alright guys, I am looking at buying a Pro 4, standard kit, new in box. What are the absolute needed extras for this car? It will be run on carpet, so I know I will be chasing down a front diff for it. What are the recommended hop ups and changes I need for the car? Thanks.
Guess who's decided to play again???
HB Racing/Team Orion
Gary Fliegel is offline   Reply With Quote
Old 11-15-2005, 05:43 PM   #13394
Chrisgt2's Avatar
Send a message via MSN to Chrisgt2 Send a message via Yahoo to Chrisgt2
Definatly want the thicker chassis....either HPI or the BMI kit since it comes with the lowered shock towers as well. Stock towers dont let you put the body low enough for foamies
Hot Bodies Pro 5
*Sponsors*
Hot Bodies, Speed Passion, Team Scream Racing, Rockstar Paint
Franchise Racing Products
The Raceway - Beaver, PA
Chrisgt2 is offline   Reply With Quote
Old 11-15-2005, 05:44 PM   #13395
3mm chassis and top deck.
Also HPI makes some hopup shock pistons,bladders, and o-rings. I would look into those as they do smooth the shocks.They aren't a necessity, but if I wear gonna build them I would go with the firm bladders and the low friction 30 o-rings, 1.1 mm pistons.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
