Like Tree6Likes
Old 11-08-2005, 12:00 PM   #13336
Im running on a tight med. traction carpet.
What is a good base spring rate and sway bar that I should go with?
I run the D pink in Rear
D Pink/ orange in the front
Alfa body. and 3+ upper and lower deck from BMI
Thanks for the info
kyracer is offline   Reply With Quote
Old 11-08-2005, 12:16 PM   #13337
fjm9898's Avatar
i have never ran foam. but ont he seup i asw on HPI's site they had 30lb in the front and 25lb in the rear.
check their site and you will probably get a great starter seup from thad or andy
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 11-08-2005, 12:30 PM   #13338
I saw the setup they have but that brings up another question I have.
where do i find such a spring rate of 30lb and 25lb.
Everywhere I have looked they are color coded and the spec. never say (30lb). Most are in grams and diameter and # of coles.
What brand and color code is 30lb and 25lb springs?
Old 11-08-2005, 12:39 PM   #13339
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by rc-zombies
yes it is..about 5mm shorter...
very smooth.
THANKS RZ- Do you know if there are lower shock towers to take advantage of this?
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-08-2005, 12:56 PM   #13340
rc-zombies's Avatar
no new shock tower..
the HB cyclone shocks are even shorter...
Old 11-08-2005, 01:07 PM   #13341
Thanks for the help. Right now I have 1 1/4 ounces right down the center line of my car. Should I try moving that to the electronics side of my car?
Kyracer- I am running carpet, pretty tight with medium traction I would say. I am also running the alfa body, but with parma magenta tires in the rear and cyans up front. Those are supposed to be close to the Jaco's though. I am running 30 lb purple associated springs up front with 70wt oil and 25 lb gold associated springs in the back with 50 wt oil. The shock and camber locations along with all the other info can be found here... http://www.hpiracing.com/graphics/se...land%20rev.pdf Thats Andy Moores setup sheet.
HPI also has a couple other setup sheets here... http://www.hpiracing.com/index2.htm
Fantom11 is offline   Reply With Quote
Old 11-08-2005, 01:10 PM   #13342
rc-zombies's Avatar
yes...put the extra weights on the right of the motor and on the side of the servo...putting it on the center line doesn't help balance the car left to right.
Old 11-08-2005, 03:45 PM   #13343
CPatrick's Avatar
Send a message via MSN to CPatrick
Default Springs 30lbs/25lbs.
kyracer,
I have the same spring setup as Fantom11. I believe the 25lbs Associated springs are "copper," not "gold."
You can convert lbs./in. to gF/mm by multiplying the lbs./in. by .05588.
400 gF/mm x .05588 = ~22.35 lbs./in.
22.35 lbs./in. / .05588 = ~400 gF/mm
CPatrick is offline   Reply With Quote
Old 11-08-2005, 03:52 PM   #13344
CPatrick's Avatar
Default Gear Ratio?
Hey Guys,
I was wondering what final drive ratio (FDR) you're running on carpet with foams? I'm running an EA Monster Stock motor and I have a 98t/64 pitch Spur and a 30t/64 pitch Pinion. My FDR is 7.9625 with a total roll out of 23.5 mm. Am I geared too low? I'm thinking of going to a 34t pinion to get my FDR around 7.0257.
The track is about 90' x 50'.
Thanks!
Old 11-08-2005, 08:30 PM   #13345
fjm9898's Avatar
you can also use AE springs they all come with their LBS rateing on the package and they usually are closer to their accual rating then HPI srpings. i just grabed up a AE spring set and use that over the HPI springs
Old 11-09-2005, 01:31 AM   #13346
THANKS ALL that helped alot!
I have not ran carpet TC for some time. I have been running 8th dirt. Trust me Im taking notes. I will try the Andy Moore setup as well. With a little luck I will only need to make a few changes for stock/ 19t racing.
Old 11-09-2005, 01:53 PM   #13347
Hi fellas, most people tend to recommend the Roar Nats 2004 Hara setup. That is obviously for modified, do you think it will suit stock ? what about the shock oil/spring combo ? and lastly, those who may havve tried it, did u use the 1mm spacer under the steering bellcranks ?
jim beam is offline   Reply With Quote
Old 11-10-2005, 12:20 AM   #13348
Default pro 4
hi i was wondering if anyone could give me a set up i could use i run on carpet with foams anything would help
thanks matt
snap_u2000 is offline   Reply With Quote
Old 11-10-2005, 12:38 AM   #13349
fjm9898's Avatar
yea i use haras 04 nats in both stock and 19t and its worked great!
Old 11-10-2005, 12:31 PM   #13350
Im trying to find a stock/19T setup for carpet as well. Next week I am going to try the Andy Moore setup found on the HPI web site. I was told its a good starting point. I will post the results around 22nd.
