Old 10-30-2005, 11:43 AM   #13246
Scottmisfits's Avatar
What should I try and target for a rollout? I'm using a stock motor and foam tires.
I have searched this thread and the search didn't seem to be very helpful. Maybe I'm just looking the wrong way.
Thanks for the help on this.
Scottmisfits is offline   Reply With Quote
Old 10-30-2005, 04:03 PM   #13247
Send a message via AIM to Re~Mix
Hi, I'm looking to run this car as a sort of asphalt basher. I was wondering whether or not the pro 4 was a good choice for that. I'd raise it up as high as I can, but im not sure if the chassis design is all that good for my purpose. Am I stuck with a tube design for my purpose? I'm not abusing the car, but it isn't a race track.
Re~Mix is offline   Reply With Quote
Old 10-30-2005, 04:20 PM   #13248
Hope you not doing any jumps or anything with it lol
Richard
Clangeddin is offline   Reply With Quote
Old 10-30-2005, 05:03 PM   #13249
Ohh, of course not. Just testing the waters.
Old 10-30-2005, 08:29 PM   #13250
josh69162's Avatar
Send a message via AIM to josh69162
Does anyone have a set up for rubbers with a oneway on asphault? There's only Thad's setup for SoCal raceway. Will that put me in the general ball park? It's definately too cold for 36R's, and we don't use traction compounds here. Why would they include a one-way if the spool is clearly used more?
-Josh
josh69162 is offline   Reply With Quote
Old 10-30-2005, 09:13 PM   #13251
newracer's Avatar
R/C Tech Charter Subscriber
Default Asphalt foam setup
Sorry it took me a while to post been veru busy. I have used this setup with foams and rubber on prepared asphalt with good success.
Hara chassis plus more
Front
one-way diff
4 degree blocks
0 toe
white springs with 40wt oil
outer hole on bottom, 2nd hole from outside on top
rear inner hole for camber link with 2mm spacer (I have the carbon fiber mounts)
black swaybar
2mm block spacers front and rear
Rear
3 degree toe
pink springs with 30wt oil
middle hole on bottom, 2nd hole from outside on top
rear inner hole for camber link with 1mm spacer (I have the carbon fiber mounts)
copper swaybar
2.5mm block spacers front and rear
5.5mm ride height front and rear
droop settings are what ever the manual recomends for initial setup
I have run this in stock and mod, stock it is planted, mod the rear is a little loose off power but I like it that way.
newracer is offline   Reply With Quote
Old 10-31-2005, 02:28 AM   #13252
JonboyGB's Avatar
Originally Posted by jamescam
Is HPI oil on par with Associated Oil? I want to duplicate Hara's ROAR Nats Asphalt set up and it calls for 45 in front & 35 in back but no LHS carries HPI oil. Will 45 & 35 Associated Oil be on par?
I would say yes.
Iíve copied Andy Moores set-ups in the past, he states HPI oils but Iíve just used AEís. Used the same oil weight and the car has been spot on.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-31-2005, 11:04 AM   #13253
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
here are pros and cons of ea camber plate
graphite: pros: cheap, the screws no longer stick up high enuf, so you dont have to do upper deck mod. lightweight cons: must use nut to hold ballstud in place (sux), only has 4 screw holes
aluminum: pros: holes are tapped so you dont have to use the nut!! has 5 holes cons: expensive, screws stick up to normal height, so you have to do upper deck mod, slightly heavier.
so i say if you have plastic get alum, and if you already have graph its prolly not worth the $$ to swtich to aluminum.
floodo1 is offline   Reply With Quote
Old 10-31-2005, 11:09 AM   #13254
floodo1's Avatar
hpi springs are really good for the pro4 because the spring rates are soooooo close together, you can make what would be half or 1/3 changes compared to other manufacturers springs.
gooo hpi springs!
Old 10-31-2005, 11:29 AM   #13255
rc-zombies's Avatar
I agree...
but the aluminum version by Jet is relatively 1/2 the price of HPI's. and cost about the same at HPI's CF plates... Jet aluminum camber plate is about $17.00 ea... and about $20.00 shipped from HK.
Old 10-31-2005, 12:12 PM   #13256
JHardy's Avatar
Default help
Just got me a Pro4 and have 2 questions.....Im tired of reading 500 pages of comments.
1. What parts do I need to make it a HARA Edition?
2. Where is the best webpage to get the coolest hop-ups/add-ons
Thanks for the help, this section has been great
JHardy is offline   Reply With Quote
Old 10-31-2005, 12:31 PM   #13257
Nicadrauspro4's Avatar
Finally, it's the answer to my question that I've been waiting for. I guess, I'll go for aluminum instead of the graphite plates.
Thanks floodo1
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 10-31-2005, 12:33 PM   #13258
Check out this link:
http://www.rc411.com/pages/reviews.php?review=39&page=1
Old 10-31-2005, 12:41 PM   #13259
JHardy,
Sorry, wrong link. Here's the right one...
http://www.rcinfusion.com/CategoryLi...x?CategoryID=4
Old 10-31-2005, 02:37 PM   #13260
JHardy's Avatar
Default Thanks
thanks for the link.
Where can I get a carbon drive shaft?
