Like Tree6Likes
Old 10-28-2005, 04:09 PM   #13231
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by arrow195
I just finished building my RS4, man is it fast. Only one problem, if I give it too much throttle the rear-end gets very loose. Also when I release the throttle it swaps ends. I haven't raced on-road in quite a while and I have no idea where to begin. Any suggestions? Thanks
Both ends are loose- sounds like tire issues. Also check your droop (add more front , less rear), tweak, shocks and diffs. You should download Haras 2004 Nats set up.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 10-28-2005, 04:36 PM   #13232
Are you running the oneway?sounds like the rear dif is to tight and you need to take any drag break out of the car in stock in should roll when trigger in is the nutral pos.
no1uno is offline   Reply With Quote
Old 10-28-2005, 06:33 PM   #13233
Cool
Thanks, I will take a look at those things and make sure my diffs aren't too tight.
arrow195 is offline   Reply With Quote
Old 10-29-2005, 02:47 AM   #13234
Default hpi pro 4 2004 vs xray t1fk 04??
hey looking at buying a second hand car. which of these to is the most reliable a few people said the pro 4's front dive chips teeth is this true or is it because of bad mesh? im gonna be running stock which is the better car??? or should i buy a new tc4??? im really confused people keepsaying ones reliable then say it isnt are they both reliable cars??
aus jd 2703 is offline   Reply With Quote
Old 10-29-2005, 05:01 AM   #13235
Matt Pocknell's Avatar
Its true, you can break teeth off the bevel gears on pro4's, but with stock racing it is very very unlikely.
Ive been running 19t spec all season and broken one bevel gear....all due to a bad mistake from me at a fast part of the track....and unforgiving track markings .
Matt
Mirage Racing|Hot Bodies|Nosram|Orion|Edit|AH Racing Products|Hudy|VRC
Matt Pocknell is offline   Reply With Quote
Old 10-29-2005, 08:11 AM   #13236
Essnowyt's Avatar
Send a message via AIM to Essnowyt
If you out fit your pro4 with a front diff, you will not chip the teeth. I am still running 1.0 gears with a front diff, and I havenít had any gear failures.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 10-29-2005, 11:32 AM   #13237
Yeah, I agree. Take the one-way out and install a diff and you won't have any problems!
John Warner is offline   Reply With Quote
Old 10-29-2005, 12:41 PM   #13238
Default Shock Position
Hi guys can you explain to me how the shock position works as i am running on med grip asphalt and would like to know how i can tune it further.
Thanks for helping
speed6 is offline   Reply With Quote
Old 10-29-2005, 02:19 PM   #13239
Nicadrauspro4's Avatar
I'm upgarding my camber. Which do you guys think is better? The graphite camber plate or the aluminum camber plate from the 2005 edition? Has anyone here tried using both? What difference does it have? By the way, I run my car on asphalt track.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 10-29-2005, 09:34 PM   #13240
josh69162's Avatar
Send a message via AIM to josh69162
aus jd 2703- The TC4 will chip teeth, too. It all depends on what you use to get power to the wheels- a diff, one way, or spool. One ways and spools will both have problems with chipping teeth. I have an aluminum front bevel gear, so I don't have problems at all, but a diff will be fine. Spools and one ways (only on-power) don't allow the wheels to spin independantly, so it's really hard on the gears. This is the same with the TC4. A guy at my local track took his spool out after a race, and was missing literally half the teeth. And yes, a bad mesh WILL make it easier to chip teeth, but a GOOD mesh is easy to get. Either car will suit your needs, but since the TC4/Pro4 are relatively similar, they will have similar problems. Don't let those people fool you by saying a Pro4 has gears that strip easy.
josh69162 is offline   Reply With Quote
Old 10-30-2005, 05:37 AM   #13241
CPatrick's Avatar
Send a message via MSN to CPatrick
Default Shock Springs
Guys,
I'm having trouble figuring out which front and rear shock springs I should purchase. The HPI Shock Spring Chart seems to be outdated, and as far as I can tell, the Hara edition springs are all 400 gF/mm (22.4 lbs/in). Isn't 22.4 lbs/in a little soft for the front of the car?
I'm purchasing a couple Hara edition shock kits for my Pro 4, and any help on the makes and models of your preferred springs and oil match ups would be greatly appreciated.
Thanks!
CPatrick
CPatrick is offline   Reply With Quote
Old 10-30-2005, 05:41 AM   #13242
JonboyGB's Avatar
best thing to do is treat yourself to the hpi spring kit. as well as get all 7 pairs of springs youíll get an up-to-date spring chart.
www.zen-racing.co.uk
JonboyGB is offline   Reply With Quote
Old 10-30-2005, 09:05 AM   #13243
Scottmisfits's Avatar
I still have my Associated spring kit from when I sold my Losi. I'm going to try purple(30lb) in the front and copper(25lbs) in the rear. I am also trying 35 weight Losi oil in the front and 32 1/2 in the rear. I had the stock silver springs on before and it was way to soft. I might try going harder on both springs and oil as well. We'll see what happens on Wednesday.
Scottmisfits is offline   Reply With Quote
Old 10-30-2005, 09:52 AM   #13244
ali_g's Avatar
guys any chance a yok spool fit into our pro4?
ali_g is offline   Reply With Quote
Old 10-30-2005, 10:04 AM   #13245
jamescam's Avatar
R/C Tech Charter Subscriber
Is HPI oil on par with Associated Oil? I want to duplicate Hara's ROAR Nats Asphalt set up and it calls for 45 in front & 35 in back but no LHS carries HPI oil. Will 45 & 35 Associated Oil be on par?
jamescam is offline   Reply With Quote
