Like Tree5Likes
Old 10-16-2005, 09:38 AM   #13126
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
Originally Posted by rc-zombies
Square makes 2 different Ti axles for the pro4. standard CV's that is found in other kits. and another that is MIP compatible. and does not require the use of Ti axles...
ahhhhhhh
thx got the p/n??
floodo1 is offline   Reply With Quote
Old 10-16-2005, 10:12 AM   #13127
Scottmisfits's Avatar
Thanks John
Scottmisfits is offline   Reply With Quote
Old 10-16-2005, 01:19 PM   #13128
V12
V12's Avatar
Someone told me HPI makes a special version of the plastic ballends what is much stronger and there wont be slop over a long time. Seems filled with graphite fibers. Someone knows what Part# this is?
Classic RC - http://classicrc.wordpress.com/
V12 is offline   Reply With Quote
Old 10-16-2005, 07:09 PM   #13129
floodo1's Avatar
heavy duty ballcups
they have moly grease in them (not graphite).
sorry i dont have p/n tho. you could check the hara edition (pro4) manual for them tho.
they are pretty sexy saying hpi right on them
Old 10-16-2005, 07:15 PM   #13130
Trader Rating: 16 (94%+)
This is them, the ones that come with the pro4 '05/hara and cyclone are the 18mm ones, second link.
http://www2.towerhobbies.com/cgi-bin...?&I=LXZT49&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXZT50&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXZT51&P=7
domo is offline   Reply With Quote
Old 10-16-2005, 11:01 PM   #13131
Help Please
I have a problem on a very bumpy track where my car bounces a lot more than other guys running the same exact setup on their Pro4's. I have tried softening the rear spring but that just exaggerates the problem. I have also gone thinner on the shock oil. Any suggestions please
rudster is offline   Reply With Quote
Old 10-17-2005, 12:04 AM   #13132
V12
V12's Avatar
Thanks guys that was what Im looking for.
Old 10-17-2005, 02:24 AM   #13133
ElectricConvert's Avatar
Originally Posted by rudster
Help Please
Try adding more droop.
ElectricConvert is offline   Reply With Quote
Old 10-17-2005, 08:32 AM   #13134
kewdawg's Avatar
Help Please
How long has it been since you rebuilt your shocks (new shafts, bladders, foam spacers, orings, plastic spacers)?
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 10-17-2005, 09:41 AM   #13135
My Pro4 with Tekin G9 plus purple heat sink & Tekin Receiver
G2B Anthony is offline   Reply With Quote
Old 10-17-2005, 09:49 AM   #13136
rc-zombies's Avatar
very nice...
if you need more room for electronics...
add 2mm servo spacer between the servo ears and mount.
that's what I did on mine...
Old 10-17-2005, 10:23 AM   #13137
tandman's Avatar
Send a message via Yahoo to tandman
Scott, for the monster stock I am running 24-25 tooth pinion with a 75 spur gear, my tires are about 58-60 mm though so pretty small. With the P2K and taller tires I would start out at 25-26 and adjust from there.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks
tandman is offline   Reply With Quote
Old 10-17-2005, 01:11 PM   #13138
Nicadrauspro4's Avatar
Hi guys! Here are pics of my pro4.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 10-17-2005, 03:38 PM   #13139
Thanks Tandman
Old 10-17-2005, 04:29 PM   #13140
MikeR's Avatar
Trader Rating: 15 (100%+)
Hey rc-zombies,
Remember me from back in the Pro3 days? Anyway I'm back for more but with the Pro4 now in the stall. My question is do you have experience with the 2, 2.5, or 3mm chassis? I have a 3mm on my car and wanted to lighten it up for 19turn asphalt racing. I know the consensus is that thinner chassis generally works better on asphalt but I wanted to get your take before I swap out the 3mm.
Best
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
