Like Tree6Likes
Old 10-13-2005, 01:48 PM   #13111
motor mount has a slight advantage if you want more steering it does move the motor forward 2mm and is much easyer to get motor out
no1uno is offline   Reply With Quote
Old 10-13-2005, 02:40 PM   #13112
badKarma's Avatar
Send a message via AIM to badKarma Send a message via Yahoo to badKarma
The Hara Edition seems like it has more advantages, but its also $100 more. Why is everyone saying that the Pro-4 is for carpet and the Hara is for asphalt?
badKarma is offline   Reply With Quote
Old 10-13-2005, 03:48 PM   #13113
farls3589's Avatar
Send a message via AIM to farls3589
Would anyone have a setup sheet for a low med and high bite set up for a pro4 and it will be with foams.
farls3589 is offline   Reply With Quote
Old 10-13-2005, 09:43 PM   #13114
CPatrick's Avatar
Send a message via MSN to CPatrick
Cool Titanium CVD Project
Titanium CVD project update...
It's not going well with my friends machine shop. I stopped in today to see if they had worked on the CVD's. Instead, they came up with ways to re-engineer the drivetrain. *#%$#@* engineers!
I'll keep trying. In the meantime, I'm making a modern art piece out of my bent CVD's.
CPatrick is offline   Reply With Quote
Old 10-13-2005, 10:20 PM   #13115
josh69162's Avatar
Send a message via AIM to josh69162
That's hilarious! I almost fell out of my chair when I read that... But what can you do? They are engineers. You should have just brought the bone in and said, "Do this in titanium, now." But I'm curious. What were their ideas on the drivetrain?
-Josh
josh69162 is offline   Reply With Quote
Old 10-14-2005, 09:05 AM   #13116
rc-zombies's Avatar
wouldn't it be just easier to buy the Ti cvds?
Square makes them a direct replacement.
Old 10-14-2005, 04:20 PM   #13117
CPatrick's Avatar
Default Son of Titanium CVD Project
Yea, zombies, I'm with ya. I've already ordered 2 sets. I approached these guys, 'cause they discard or recycle enough titanium in one day to supply all of us with a couple sets of CVDs. All I can say is that they are a US Navy defense contractor. There's just no way I could have snuck something onto the production floor without the managers and engineers knowing about it. Hell, I wrote the software that alerts them to changes in machine queues and manufacturing schedules.
These guys were on the path to the bone type axles found in something like the HPI Sprint. It's already been done, but they don't know that. The difference in size and weight of the two CVD axle ends had them rubbing their beards.
I just grabbed my chassis, and let me friend know that if he wanted his business name on my car, then it was going to cost him some titanium CVDs!
Old 10-14-2005, 04:54 PM   #13118
josh69162's Avatar
So these CVD's aren't going to be made?
-Josh
Old 10-15-2005, 03:08 PM   #13119
floodo1's Avatar
Send a message via ICQ to floodo1 Send a message via AIM to floodo1 Send a message via Yahoo to floodo1
what do you mean square makes them a direct replacement?
also isnt it true that the ti-racing cvd's use a difference axle than the mip cvd's, meaning that you have to use ti-racing axles with ur ti-racing bones?
also im just guessing here, but if the axle and bone are different then you probably can't use mip cvd rebuild kits with the ti-racing setup...correct?
floodo1 is offline   Reply With Quote
Old 10-15-2005, 03:24 PM   #13120
Scottmisfits's Avatar
What kind of gearing are you guys using for stock? I'll end up going with 48pitch as I already have all my pinions.
I have P2K and a Monster. I might run a little mod with 13 turn as we have a pretty small track.
Thanks for the help.
Scottmisfits is offline   Reply With Quote
Old 10-15-2005, 06:22 PM   #13121
rc-zombies's Avatar
Square makes 2 different Ti axles for the pro4. standard CV's that is found in other kits. and another that is MIP compatible. and does not require the use of Ti axles...
Old 10-15-2005, 09:47 PM   #13122
Nobody has any info for gearing with a 48 pitch set up?
Old 10-15-2005, 10:06 PM   #13123
fjm9898's Avatar
every track is different... ask guys at ur local track to help you out
Xray '007 US and a bunch of other outdated stuff
fjm9898 is offline   Reply With Quote
Old 10-15-2005, 10:19 PM   #13124
The tracks might be different but there is a decent starting point to gearing. I know that. And the only guy thats at the track with one runs 64 pitch.
Old 10-15-2005, 11:16 PM   #13125
You might find some help with gearing here...... http://www.gearchart.com/index.cfm?f...n=chart.create
John Warner is offline   Reply With Quote
