Hpi Pro 4
Originally Posted by jamescam
Does anyone make aluminum battery bar mounts? I am not a fan of the plastic ones and would like to switch these to aluminum like I have on my XRay.
Tape has alot of benefits over the strap.
1. Doesn't tweak chassis when batteries are secured.
2. Weighs much less than strap.
3. Less likely to have the batts come out.
4. No body clips to lose after you take the batteries out.
But the aluminum strap sure looks pretty
This Pro 4 will be my asphault car. Asphault isn't very competitive where I live so I am considering ease of use & looks over performance benefits.
Cool.
Yeah, sometimes the "bling factor" comes into play quite well.
Set-up advice
I am running stock/rubber on carpet. Any set-up tips would be awesome. Thanks.
One thing I've learned is that you should run almost zero droop. I was cruisin with a one-way with foams on carpet, and with any bit of droop, the rear would finds its way out in front. Granted, this would probably be much better with a spool or diff, but I didn't have it at the time.
-Josh
-Josh
ttt bump
here's a pic of my pro4
Nice Inversion
If I could only find paint in this color
just received the 3-racing clip-on motor heatsink w/built in fan..
a bit dissappointed... fan does not put out a whole lot of air if plugged into the receiver.. does do a better job if the wires are hardwired to you batter wire leads. the Unit come prewired with plug and extenion lead to direct solder.
Stock Set-ups
Anybody out there with any stock set-up for the Pro 4??? Any help would be much appreciated. I will be running on carpet with rubber tires. Thanks!
if your track is larger with less sharp corners the DHI 2005 setup may be better.
the DHI 2004 setup is in the back of the reg manual, and the DHI 2005 setup is in the back of the 2005/hara manual.
Pro4 Setup Sheets
SNIDE...
Did you pull down the setup sheets available on the HPI website?
http://www.hpiracing.com/index2.htm
Navigate through Instructions / Setup Sheets / Pro4
Chad's Pics
Come on ChadCapece!
Give us the non "Paris Hilton sex video" version of your Pro 4 pics! I want to see what 5 minutes of freespin looks like.
