Old 09-21-2005, 05:17 PM   #12916
jamescam's Avatar
R/C Tech Charter Subscriber
Originally Posted by ChadCapece
check out my setup for medium traction asphalt. Hara's setup for high traction asphalt.
Found Hara's, could you point me to yours? Also, while I am sure the Pro 4 (non Hara edition) is a killer on asphalt out of the box can you recommend any good hop ups for asphalt? I like the new shooters front spool but not sure if that is more for bling or performance (either way I will probably get it
jamescam is offline   Reply With Quote
Old 09-21-2005, 05:18 PM   #12917
ChadCapece's Avatar
Here's my winning setup on medium-high traction bumpy asphalt:
Carolina RC
Qualifier 1 Qual 2 Qual 3 Main
Laps/Time DNF TQ 2nd Q 1st A-Main
Fast Lap (sec) 16.46 16.51 16.46 16.08
Track Temp. (F) 120 125 130 130
Diam. RF (")
Diam. LF (")
Diam. RR (")
Diam. LR (")
Tire/Rim F RP 30's RP 30s CS 27's 10runs CS 27's Stickers
Tire/Rim R " " " "
Motor binary stk Monster stk Monster stk binary stk
Timing, Comm. D.
Brush/Spring (+) green red red green
Brush/Spring (-) green green green green
Gear (p-s) 98-34 98-36 98-36 98-34
Rollout (")
Battery gp 3300's 1.18 IB 3600 rc professor IB36 gp 3300 1.18
Charger/Amp/Peak 5.0-40mV " " "
Tract. Cmp. F/R none " " "
Ride Height F (mm) 5.5 5.5 5.5 5.5
Ride Height R (mm) 5.5 5.5 5.5 5.5
Up travel F (mm) " " "
Up travel R (mm) " " "
Droop Front 3mm 3mm 3mm 3mm
Droop Rear 3mm " " "
Front Spring " " "
Rear Spring " " "
Oil, Piston Front " " '
Oil, Piston Rear " " "
Block Car. 4 degrees " " "
Roll Center F (O,Δ) (tabs)
Roll Center R (□,X)(tabs)
Roll Bar F none none stk bar stk bar
Roll Bar R none none stk bar stk bar
Toe Fr., R () 0,3 0,2 0,3
A-dive/K-up,A-/Pro-Squat
Wheelbase F (O,Δ), R (□,X) stk
Camber F (R/L) 0.5
Camber R (R/L) 0.5
Bump steer, Ack., Knuck. stk
Shock F Mount (T, A)
Shock R Mount (T,A)
Camber F Mount
Camber R Mount (hub)
F/R Drive, Batt. Pl. spool/diff
ESC/Receiver/Servo QC1, RS300, 94757
ESC Settings Modified punch control
Body/Wing Mazda6, ROAR legal wing
Dual Rate 91% 93% 99% 99%
Car Pro4 pro4 pro4 pro4
Weight (g) 1500 1516 1516 1516
Comments VERY FAST stable, but tight loose perfect
Tweak (F/R Solid)
Discharge (mAh)
Weight (oz)
Transmitter Settings
St Curve (%) -4%
Th Curve (%) LN
Th Hipoint
Th Brake No drag
Shock LF/RF
Shock LR/RR
I can email you the excel document if this is too hard to read.
ChadCapece is offline   Reply With Quote
Old 09-21-2005, 06:17 PM   #12918
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
What are your front and rear roll center settings?
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
SOuthernFRIED is offline   Reply With Quote
Old 09-21-2005, 06:19 PM   #12919
ChadCapece's Avatar
stock shims under ball cups and a-arm mounts.
Old 09-21-2005, 06:35 PM   #12920
jamescam's Avatar
Here is the new body to go with my current Pro 4 project. While the Lotus may not be the best race body but drapped in purple it sure is pretty
Old 09-21-2005, 06:41 PM   #12921
ChadCapece's Avatar
Nice
Old 09-21-2005, 07:12 PM   #12922
thanks for the info
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
Old 09-21-2005, 07:16 PM   #12923
ChadCapece's Avatar
Originally Posted by SOuthernFRIED
thanks for the info
Are you going to do the ROAR region 3 race?
Old 09-22-2005, 06:22 AM   #12924
When? Where? Gimme some details , we may try to hook it up.
James Cooper
SouthernFriedRacing
teamsfr@gmail.com
Old 09-22-2005, 11:07 AM   #12925
CPatrick's Avatar
Send a message via MSN to CPatrick
Default Aluminum Steering Bell Cranks
Hey Zombies!
I was looking at the pics you posted for the upper plate tweak mod and noticed purple aluminum steering bell cranks on your ride. Are you using the set made by 'Dynamite?'
CPatrick
CPatrick is offline   Reply With Quote
Old 09-22-2005, 11:16 AM   #12926
rc-zombies's Avatar
Originally Posted by CPatrick
Hey Zombies!
CPatrick
but mine is made by Futaba.
switched to KO servo..getting the dynamite ones soon.
I like the dynamite ones..they are pre-threaded for 3mm ball studs.
Old 09-22-2005, 12:42 PM   #12927
ChadCapece's Avatar
Sometime in November. Some of the NC boys were trying to get me to come. I think the race is at the carpet track in nashville.
Old 09-22-2005, 04:45 PM   #12928
rc-zombies's Avatar
Something new that will fit the Pro4 and other cars as well...
only $9.00 shipped from HK.
found on Ebay...available in black, purple, ti and blue...
for now blue is the only one available... I just bought the others..
Old 09-22-2005, 05:07 PM   #12929
ChadCapece's Avatar
Looks trick, any chance they make one that blows on the endbell?
Old 09-22-2005, 05:10 PM   #12930
rc-zombies's Avatar
to cool the endbell... I was thinking of moving the fan to the outer holes...
the one by trinity does..it's screwed directly into the endbell. replaces the eyelit screws.. I have these as well..and works good if space is not a factor.
http://www2.towerhobbies.com/cgi-bin...?&I=LXJKA9&P=7
