Hpi Pro 4
check out that wild paintjob
Anyone know where I can get a set of Pit 30's,One more,are the RP 30's about the same as the pits??
Originally Posted by xxxkat
Anyone know wher I can get a set of Pit 30's,One more,are the RP 30's about the same as the pits??
Ok, I could use some advice. I'm in the process of rebuilding my Pro4. i'm using the schumacher ball cups again, but this time I'm going to drill holes so that I can access the ball studs with my wrench, but I've got a problem. the ball cups fit perfectly before I drill the hole in the cup, but after I drilll, the cup is WAY to tight! no way the suspension will work with that.
So to those of you who've done this to your schumacher ball cups, what tools did you use and exactly how did you do it? No matter what I use or how I do it, I can't seem to get the ball cup to be usable after I drill.
ChadCapece
I see by your Avitar you're a Falcons fan..?
that was a pretty good game today agains my Seahawks..
Go SF Giants!!
Roger and Aurra Sing,I would guess that you guys are going to run at stockton this year?? I run the same carpet that Stockton is going to use this year and the Pitt 30's are so hooked up it.. I am just trying to find some,Aurra Sing do you know floodo1(Josh)He will back me up on this..how fast my Pro4 is on pitt 30's.. on carpet,I'm beating the foam guys in 19 turn with rubber tires..dang this Pro4 is way fassssst..
Haha... no i dont know him... but doubtful any of us will be running Pits this carpet season (a lot of us including myself will be switching to 12th scale!) but it seems that RP's and Sorexs will still be the tire for Stockton. Besides, i have never gotten my Pro4 to work well on carpet w/ rubbers but it works great w/ foamies
I tried some 28's(sorex's)car was a bit to hooked,up so i tried some 32's,They were a bit skatey for me.On my pro4 I'm using a BMI 3mm chassis,seems to work great.
PIT 30's ? You mean these things ? ( muhahahahahah )
cartmen- when you drilled the ball cups did you drill from the inside out or outside in. I always drilled the HPI cups without problems. Drill from the inside(where the ball would go) to the outside using a sharp bit and little pressure, let the bit do the work. Also, don't make the hole to big, just tight enough to get a 2mm tip thru it. You shouldn't notice any difference in tightness once done.
DIZZY1 you going to vegas? what happend to you and ron on fridays?
No1-I cancelled Vegas, new job starts soon and had to cancel my vacation at work. Been 2wd on Thursday lately. Should be out to the pavement soon.
thanks again!!
