Old 09-12-2005, 09:41 PM   #12811
rc-zombies's Avatar
the Hara upper deck does not include the hardware for the o-ring mod.
thickness of it is not thinner...
the thinnest HPI upperdeck is 2.0mm
and thickest is 2.5mm
the Hara upperdeck is 2.25mm.
it was designed to have more lateral flex and still be stiff front and back
Old 09-12-2005, 09:49 PM   #12812
ngo8's Avatar
Send a message via ICQ to ngo8
does anyone have any pict of the mod ?
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 09-12-2005, 09:51 PM   #12813
rc-zombies's Avatar
I posted pics a handfull of pages back...
Old 09-12-2005, 10:49 PM   #12814
ngo8's Avatar
Originally Posted by rc-zombies
Aside from drilling out the holes... you'll have to do the o-ring mod as well.
you'll need: 2 o-rings, 2 cone washer, 2 button head screw. assemble as shown. do not tighten screw all the way down. should be about .5mm-1mm gap between the washer and upperdeck.
see pics.
nw racer: the purpose for this mod to help minimize any chassis tweak in the event of a hard crash. just drill out the hole just big enough for the screw head to pass through. the car will still be stiff with the stock chassis and upperdeck and you'll not have to change your driving style...what kind of track are you running? if you're running carpet at Raincity. recommend getting the stiffer 3mm chassis and upperdeck. asphalt..stay with the stock set-up.
centax error!.... the arms are great for low traction tracks...they are hard to get and available overseas. another option is stay with the stock arms and get the 2mm chassis.
ok for those wondering the picts of the oring mod provided by are good friend rc-zombies is on page 397
Old 09-13-2005, 04:07 AM   #12815
ChadCapece's Avatar
Not everyone is going to have the same page numbers b/c they don't have the same post count per page
ChadCapece is offline   Reply With Quote
Old 09-13-2005, 05:43 AM   #12816
I found it located here......Hpi Pro 4
It's post number 11890
John Warner is offline   Reply With Quote
Old 09-14-2005, 08:03 AM   #12817
cartmen34's Avatar
Originally Posted by cartmen34
Speaking of the o-ring mod, has anybody tried at Hara-spec upper deck on carpet?
I'm currently using a BMI 3mm main chassis and upperdeck on my carpet Pro4, but I usually have a tweak problem after a slight tap on the boards. Usually it not too bad and I can just drive around it (albiet more slowly!), but it is still annoying to have to re-set my car in the pits after every tap-o-the-boards.
I know the general idea behind the Hara spec upper deck is for lateral flex, and also to prevent the car from tweaking, but will this flex do more hurt than help on carpet?
Anybody?
cartmen34 is offline   Reply With Quote
Old 09-14-2005, 08:32 AM   #12818
Skill's Avatar
I tried my 2mm top deck with the 3mm chassis for the first part of a meeting and when I changed to the 3mm the car was so much better. This isn't to say that I could have changed the setup, but I believe that on carpet with foams you need to go as stiff as possible. The hara 2.25mm top deck will probably have more lateral flex than the 2mm kit one so I'm guessing that would be even worse for carpet and foams.
Skill is offline   Reply With Quote
Old 09-14-2005, 09:18 AM   #12819
Oasis's Avatar
Trader Rating: 36 (100%+)
All i run on is carpet and i do have the BMI chassis(3mm)on my car,I have the mod done on the top deak and dont really have any tweak problems,I would think with the thinner top deck you would have more tweak issue's,not less.I check tweak after every run,If your racing on as high traction surface you should check tweak after every run,It does not take much time.I check mine even after a clean run,The way i look at it is I allready paid for it so I'm getting my moneys worth..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 09-14-2005, 03:10 PM   #12820
cartmen34's Avatar
Thanks kat...
So, by the way I read your post, you use the 3mm top deck and have done the mods to it. You think it seems to help prevent tweak.
Did you notice a difference in the car's handling before the topdeck mods as opposed to after the topdeck mods?
Old 09-14-2005, 05:23 PM   #12821
Oasis's Avatar
I did notice that I dont have to mess with the tweak as much now as I used to,But on carpet this car is a rocket..
Old 09-14-2005, 05:36 PM   #12822
I also have the BMI 3mm upper deck and chassis. The car has the Hara mod done as well. I will agree that the car is a rocket on carpet. I bought my car with everything already done, and have been looking for tweak issues but so far there hasn't been any!
Old 09-14-2005, 06:49 PM   #12823
fire929's Avatar
Default Feedback
Can anyone give feedback on the Hara Pro4
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 09-14-2005, 08:28 PM   #12824
Sleekism's Avatar
hey guy's jsut thought you'd like to see my Pro4, its not legal on any track but it pushes about 130-140kph. its got a 6turn brushless, 120amp MGM compro speedy & runs 12 cells
Sleekism is offline   Reply With Quote
Old 09-14-2005, 08:33 PM   #12825
ChadCapece's Avatar
Holly crap, that's is a sweet pro4. Anything over 80 is warpspeed for a TC. Have you tested it with anything other than the Pike's Peak body? I used to have one, and it is STUCK!!!!!!. Maybe a little too stuck
